BT.com
Wishlist
APC Symmetra PX 10kW Power Module
£5,024.25
Hurry, only 1 left in stock!
£5,024.25
Add to wishlist
Delivery
Standard 1-3 working days
  • Increases adaptability with an open architecture configurable to any IT environment.
  • Modular construction - can be deployed as a non-standby and migrate to a standby (UPS) system.
  • Provides fast serviceability and reduced maintenance requirements via self-diagnosing, field-replaceable modules.
  • Minimizes installation costs by enabling the use of smaller generators and cabling.
  • Modular design provides scalable solutions to add cooling as demand increases.
APC Symmetra PX Power Module - UPS - 16 kW - 16000 VA
UPS - plug-in module
Rack Size
3U
28.5 kg
Input Wiring
3-phase
Input Voltage
AC 400 V
Output Voltage
AC 230/380/400/415 V ± 2%
Power Capacity
16 kW / 16000 VA
Input Connectors
1 x hardwire 5-wire (3PH + N + G)
Output connectors
No battery
48.3 cm x 70 cm x 13.2 cm
1 year warranty
P/N: SY128K160H-PD, SY160K160H-PD, SY16K48H-PD, SY32K160H-PD, SY64K160H, SY64K160H-PD, SY96K160H, SY96K160H-PD
Height (Rack Units)
3U
UPS Technology
On-line
Input Voltage
AC 400 V
Input Voltage Range
AC 340 - 477 V
Frequency Provided
50/60 Hz
Input Voltage Margin
± 5%
Input Wiring
3-phase
Frequency Required
50/60 Hz ± 5%
Input Connectors
Output Voltage
AC 230/380/400/415 V ± 2% - 50/60 Hz
Power Capacity
16 kW / 16000 VA
Output Waveform
Sinewave
No battery
FCC Class A certified, FCC Part 15, EN 50091-1
Limited warranty - 1 year
0 - 95%
Sound Emission
63 dBA
48.3 cm
70 cm
13.2 cm
28.5 kg
Shipping Width
59.5 cm
Shipping Depth
70 cm
Shipping Height
22.5 cm
Shipping Weight
31.6 kg
Scroll to top
