BT.com
Wishlist
APC SYMMETRA LX EXT RUN RM
£5,782.82
£5,782.82
Add to wishlist
Delivery
Standard Due date unavailable
Hot-swappable battery ensures clean, uninterrupted power to protected equipment while batteries are being replaced.
Plug-and-Play external battery ensures clean, uninterrupted power to the loads when adding extra runtime to the UPS.
APC Extended Run - power array cabinet
Power array cabinet - rack-mountable
Rack Size
13U
313 kg
Input Voltage
AC 230 V
Lead Acid
Battery Form Factor
Plug-in module
Batteries Qty
9 (max) 9
47.2 cm x 68.6 cm x 57.2 cm
2 years warranty
Battery Enclosure Type
Plug-in module
Height (Rack Units)
13U
Supported Battery Technology
Lead Acid
Input Voltage
AC 230 V
Quantity
9 (max) 9
Lead Acid
Voltage Provided
120 V
CSA, VCCI, BSMI, EN 60950, UL 1778, VDE, IEC 60950, EN 50091-2, EN 50091-1
0 - 95%
47.2 cm
68.6 cm
57.2 cm
313 kg
Scroll to top
