BT.com
Wishlist
APC Switched Rack PDU 2G Zero U Power Distribution Unit
APC Switched Rack PDU 2G Zero U...
£1,264.72
Hurry, only 3 left in stock!
£1,264.72
Add to wishlist
Delivery
Standard 1-3 working days
APC Switched Rack Power Distribution Units (PDUs) enable advanced, user-customizable power control and active monitoring. Remote outlet level controls allow power on/off functionality for power recycling to remotely reboot equipment and restrict unauthorized use of individual outlets. Power sequencing delays allow users to define the order in which to power up or down attached equipment. Avoid circuit overload during power recovery and extend uptime of critical equipment by prioritizing the load shedding. Current metering provides real-time remote monitoring of connected loads. Switched Rack PDUs include real power monitoring, a temperature/humidity sensor port, locking IEC receptacles, and low profile circuit breakers. User-defined alarms warn of potential circuit overloads before critical IT failures occur. Users can access, configure, and control Switched Rack PDUs through secure Web, SNMP, or Telnet Interfaces.
APC Switched Rack PDU 2G Zero U - power distribution unit
Power distribution unit - rack-mountable
Rack Size
0U
8.2 kg
Input Voltage
AC 200/208/230 V
Output Voltage
AC 230 V
Input Connectors
1 x power IEC 60309
Output connectors
3 x power IEC 60320 C19 ¦ 21 x power IEC 60320 C13
Ethernet 10/100, RS-232
Remote Management Protocol
SNMP, Telnet, HTTP
5.6 cm x 5.1 cm x 183 cm
2 years warranty
P/N: AR3100, AR3150
Height (Rack Units)
0U
Input Voltage
AC 200/208/230 V
Input Voltage Range
AC 220 - 240 V
Frequency Required
50/60 Hz
Input Connectors
1 x power IEC 60309
Output Voltage
AC 230 V
Max Electric Current
32 A
Remote Management Interface
SNMP, Telnet, HTTP
1 x management (Ethernet) - RJ-45 , 1 x management (RS-232)
Power cable - external - 3 m , Serial cable - external
Rack Mounting Kit
Included
Audible alarm, LCD display, overload protection
EN 61000-3-2, VDE, EN 61000-3-3, EN55024, EN55022 Class A, RoHS, REACH
-5 °C
45 °C
5 - 95%
5.6 cm
5.1 cm
183 cm
8.2 kg
Shipping Width
16.2 cm
Shipping Depth
11.8 cm
Shipping Height
204 cm
Shipping Weight
10.5 kg
P/N: AR3100, AR3150
Scroll to top
