BT.com
Wishlist
APC Switched Rack PDU - power control unit
Delivery
Standard 1-3 working days
APC's Switched Rack Power Distribution Units (PDUs) are premium solutions to many of the power management problems seen in today's IT environments. Some of the problems are unauthorized use of power outlets, locked-up equipment, in-rush current, overloaded circuits, and the need of remote access to power outlets in the rack. The Switched Rack PDUs address these problems through individual outlet control, power on and off delays, current monitoring, alarm thresholds, and network management. Individual outlet control allows users to turn outlets on, turn outlets off, or recycle power to equipment, which can reboot locked-up equipment and avoid unauthorized use of outlets. Power delays allow users to determine the order in which equipment is powered up or down. Utilizing the power delay feature will avoid in-rush current, which can cause overloads. Monitoring the current draw at the rack level is key to avoiding downtime due to overloaded circuits. The Switched Rack PDUs provide an aggregate current draw, which can be viewed remotely or locally, via digital display. In addition, alarms will be generated based on user-defined thresholds to alert users of potential circuit overloads (on select models). Users can access, configure, and control the Switched Rack PDUs through Web, SNMP, or Telnet Interfaces.
Power control unit - rack-mountable
Output Connectors
16 x power IEC 60320 C13
Rack Size
19" - 2U
4.5 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Input Connectors
1 x power IEC 60309
Output connectors
Ethernet 10/100
Remote Management Protocol
SNMP, Telnet, HTTP
Microsoft Windows NT 4.0, Microsoft Windows 98/2000/XP
44.5 cm x 11.4 cm x 8.9 cm
2 years warranty
P/N: AR3100, AR3150
Height (Rack Units)
2U
Rack Size
19"
Output Connectors
Input Voltage
AC 230 V
Input Voltage Margin
± 10%
Frequency Required
47 - 63 Hz ± 10%
Input Connectors
1 x power IEC 60309
Output Voltage
AC 230 V
Max Electric Current
32 A
Remote Management Interface
Ethernet 10/100
SNMP, Telnet, HTTP
1 x management (Ethernet) - RJ-45 , 1 x management - RJ-11
Power cable - integrated - 3.05 m , Serial cable - external
Rack Mounting Kit
Included
LCD display, LED display
FCC Class A certified, UL, VCCI, C-Tick, cUL, ICES-003, IEC 61000-3-2, IEC 61000-3-3, VDE, EN55024, EN55022 Class A
45 °C
Min Storage Temperature
-25 °C
Max Storage Temperature
65 °C
0 - 95%
Humidity Range Storage
0 - 95%
44.5 cm
11.4 cm
8.9 cm
4.5 kg
P/N: AR3100, AR3150
Scroll to top
