BT.com
Wishlist
APC Smart-UPS XL Modular 48V Extended Run Battery Pack
APC Smart-UPS XL Modular 48V...
£838.35
Hurry, only 1 left in stock!
£838.35
Add to wishlist
Delivery
Standard 1-3 working days
APC Smart-UPS XL protects your data by supplying reliable, network-grade power with scalable run-time in tower and rack mount form factors. With optional, matching battery packs, run-time can be easily extended and optimized for the application. APC understands long run-time requirements, so Smart-UPS XLs can be configured with up to 10 additional battery packs - for run-times exceeding 24 hours, if necessary.
APC Smart-UPS XL Modular 48V Extended Run Battery Pack - battery enclosure
Battery enclosure - external
Rack Size
2U
60 kg
Battery Form Factor
Plug-in module
Batteries Qty
2 (installed) / 2 (max)
43 cm x 67.8 cm x 8.6 cm
2 years warranty
P/N: SUM3000RMXL2U, SUM3000RMXL2U-TU
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
Quantity
Voltage Provided
48 V
Limited warranty - parts and labour - 2 years
0 - 95%
43 cm
67.8 cm
8.6 cm
60 kg
Scroll to top
