BT.com
Wishlist
APC Smart-UPS XL Modular 3000VA 230V Rackmount / Tower
APC Smart-UPS XL Modular 3000VA...
£2,316.33
£2,316.33
Add to wishlist
Delivery
Standard Due date unavailable
APC Smart-UPS XL protects your data by supplying reliable, network-grade power with scalable run-time in tower and rack mount form factors. With optional, matching battery packs, run-time can be easily extended and optimized for the application. APC understands long run-time requirements so; Smart-UPS XL's can be configured with up to 10 additional battery packs - for run-times exceeding 24 hours, if necessary. The convergence of voice and data networks is placing higher demands on availability expectations - and the Smart-UPS XL delivers. Voice over Internet Protocol (VoIP), e-commerce, WiFi ("hotspots", WLAN/ WWAN, and mixed wireless), and data enabled PBX's are a few of the applications driving the need for Smart-UPS XL. APC Smart-UPS XL is also the perfect UPS for fileservers (Intel or UNIX based), minicomputers, Network switches and hubs, ATM's, telecommunications systems and other mission-critical applications requiring longer runtime.
With included PowerChute management software for servers and workstations, IT administrators can provide safe system shutdown and advanced UPS management (All major operating systems supported). Connectivity is through a serial or USB port. Additional manageability is available through the SmartSlot, an internal accessory slot that allows you to install optional accessories to enhance the performance of your UPS. Network connection with Web browser management and/or environmental monitoring, serial port expansion, and out-of-band management options are available. With pure sine-wave output ensuring compatibility with all connected devices, Intelligent Battery Management ensuring a highly available UPS and an advanced 16 segment bar graph display ensuring information and management, the Smart-UPS XL is a UPS you can count on.
APC Smart-UPS XL Modular 3000VA - UPS - 2.85 kW - 3000 VA
UPS - external
Rack Size
2U
47 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
2.85 kW / 3000 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
7 x power IEC 60320 C13 , 1 x power IEC 60320 C19
Battery Form Factor
Plug-in module
Run Time (Up To)
3.5 min at full load
43 cm x 68 cm x 9 cm
2 years warranty
UPS - external
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 285 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
50/60 Hz
Input Voltage Margin
± 5%
Frequency Required
50/60 Hz ± 5%
Input Connectors
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
2.85 kW / 3000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
490 Joules
Run Time (Up To)
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB , 1 x LAN - RJ-45
Expansion Slots
1 (total) / 0 (free) x SmartSlot
Serial cable , USB cable , Power cable - 3 m
Rack Mounting Kit
Included
Audible alarm
C-Tick, GOST, EN 61000-3-2, UL 1449, EN55022 Class A
Software Included
Drivers & Utilities
Limited warranty - parts and labour - 2 years
0 - 95%
43 cm
68 cm
9 cm
47 kg
Accessories
APC Rack Automatic Transfer Switch
Quicklinx: 53TD | In Stock
£550.56
Scroll to top
