Click to visit BT.com
BT.com
Wishlist
APC Smart-UPS XL Modular 1500VA 230V Rackmount / Tower
Quicklinx: 3P7VWS00
Mfr#: SUM1500RMXLI2U
Type: UPS
Power Rating: 1.425kW
£1,213.84
APC sets the standard in its industry for quality, innovation and support. Its comprehensive solutions, which are designed for both home and corporate environments, improve the manageability, availability and performance of sensitive electronic, network, communications and industrial equipment of all sizes. The mission of APC is to improve the manageability, availability, and performance of information and communication systems through rapid development and delivery of innovative solutions to real customer problems.
  • Boost and Trim Automatic Voltage Regulation (AVR)
    Gives higher application availability by correcting low and high voltage conditions without using the battery.
  • Intelligent battery management
    Maximizes battery performance, life, and reliability through intelligent, precision charging.
  • Power conditioning
    Protects connected loads from surges, spikes, lightning, and other power disturbances.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
  • Automatic restart of loads after UPS shutdown
    Automatically starts up the connected equipment upon the return of utility power.
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Disconnected battery notification
    Warns when a battery is not available to provide backup power.
  • User-replaceable batteries
    Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
  • Hot-swappable batteries
    Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
  • Predictive failure notification
    Provides early-warning fault analysis ensuring proactive component replacement.
APC Smart-UPS XL Modular 1500VA - UPS - 1.425 kW - 1500 VA
UPS - external
Rack Size
2U
47 kg
Input Voltage
AC 230 V
Output Voltage
AC 220/230/240 V ± 5%
Power Capacity
1.425 kW / 1500 VA
Input Connectors
1 x power IEC 320 EN 60320 C14
Output connectors
9 x power IEC 320 EN 60320 C13
Batteries Qty
1
Run Time (Up To)
11.9 min at full load
Remote Management Protocol
SNMP, HTTP
43 cm x 68 cm x 9 cm
2 years warranty
UPS - external
Height (Rack Units)
2U
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 285 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
Power Capacity
1.425 kW / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
490 Joules
Quantity
1
Run Time (Up To)
SNMP, HTTP
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x USB - Ethernet 10Base-T/100Base-TX , 1 x LAN - RJ-45
Rack Mounting Kit
Included
Audible alarm
C-Tick, GOST, EN 61000-3-2, EN55022 Class A, EN 50091-2
2 years warranty
Service & Support Details
Limited warranty - parts and labour - 2 years
0 - 95%
43 cm
68 cm
9 cm
47 kg
APC Smart-UPS XL Modular 1500VA 230V Rackmount / Tower  Bundle deal on APC Smart-UPS XL Modular 1500VA 230V Rackmount / Tower
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£1,223.83
Type: UPS
Brand: APC
Price Range Inc VAT: 1000 - 1500
