BT.com
Wishlist
APC Smart-UPS VT 30kVA 400V w/3 Batt Mod Exp to 4 Start-Up 5
APC Smart-UPS VT 30kVA 400V w/3...
£10,404.14
£10,404.14
Add to wishlist
Delivery
Standard Due date unavailable
Smart-UPS VT offers centralized three-phase power protection with the reliability of the award winning Smart-UPS family. Ideal for small data centers, large retail stores, regional offices, and dense power requirements, the Smart-UPS VT includes dual-mains input, automatic and maintenance bypasses, and scalable runtime with hot-swappable batteries for increased availability. Low cost of ownership is achieved through best-in-class efficiency and a reduction in rating of electrical infrastructure - wires, transformers, and generators due the Smart-UPS VT's soft start feature. Serviceability is greatly enhanced by user-replaceable batteries. All these features make the Smart-UPS VT is the easiest UPS in its class to deploy, manage and maintain.
APC Smart-UPS VT 30kVA with 3 Battery Modules Expandable to 4 - UPS - 24 kW - 30000 VA
UPS - external
537 kg
Input Wiring
3-phase
Input Voltage
AC 380/400/415 V
Output Voltage
AC 380/400/415 V ± 5%
Power Capacity
24 kW / 30000 VA
Input Connectors
1 x hardwire 5-wire (3PH + N + G)
Output connectors
1 x Terminal Block (Screw) , 1 x hardwire 5-wire (3PH + N + G) , 1 x hardwire 4-wire (3PH + G)
Lead Acid expandable
Battery Form Factor
Internal
Batteries Qty
3 (installed) / 4 (supported)
Run Time (Up To)
5.5 min at full load
Ethernet 10/100, RS-232
Remote Management Protocol
SNMP, HTTP, HTTPS, WAP
55.9 cm x 81.3 cm x 150 cm
1 year warranty
UPS - external
Battery Enclosure Type
Internal
UPS Technology
On-line
Input Voltage
AC 380/400/415 V
Input Voltage Range
AC 304 - 477 V
Frequency Provided
47 - 53 Hz
Input Wiring
3-phase
Frequency Required
47 - 70 Hz
Input Connectors
Output Voltage
AC 380/400/415 V ± 5% - 47 - 53 Hz
Power Capacity
24 kW / 30000 VA
Output Waveform
Sinewave
Surge Suppression
Circuit Protection
Circuit breaker
Expandable
Quantity
Lead Acid
Run Time (Up To)
Recharge Time
5 hours
Remote Management Interface
1 x management (Ethernet) - RJ-45 , 1 x EPO (emergency power off) , 1 x management (RS-232) - 9 pin D-Sub (DB-9)
Expansion Slots
1 (total) / 0 (free) x SmartSlot
Audible alarm, emergency power off, LCD display, built-in maintenance bypass, built-in static bypass
C-Tick, ISO 9001, IEC 61000-3-2, IEC 61000-3-3, ISO 14001, EN 50091-2, IEC 62040-3
Software Included
Drivers & Utilities
Limited warranty - 1 year , Installation
Sound Emission
55 dBA
55.9 cm
81.3 cm
150 cm
537 kg
Shipping Width
65 cm
Shipping Depth
106 cm
Shipping Height
164 cm
Shipping Weight
568 kg
Scroll to top
