BT.com
Wishlist
APC Smart-UPS VT 10kVA 400V
£7,955.74
£7,955.74
Add to wishlist
Delivery
Standard Due date unavailable
Smart-UPS VT offers IT professionals the performance and legendary reliability of the award winning Smart-UPS family. Expanding up through to small data centers, remote offices, Point of Sale applications and laboratory equipment Smart-UP VT is ideal for entry level and performance power protection needs. Smart-UPS VT features double-conversion on-line design and offers internal and external batteries in a user friendly, scalable design. The UPS includes dual mains input for increased availability and a built-in maintenance bypass breaker.
APC Smart-UPS VT 10kVA with 2 Battery Modules Expandable to 4 - UPS - 8 kW - 10000 VA
UPS - external
Output Connectors
3 x Terminal Block (Screw), hardwire 4-wire (3PH + G), hardwire 5-wire (3PH + N + G)
415 kg
Input Wiring
3-phase
Input Voltage
AC 380/400/415 V
Output Voltage
AC 380/400/415 V ± 5%
Power Capacity
8 kW / 10000 VA
Input Connectors
1 x hardwire 5-wire (3PH + N + G)
Output connectors
1 x Terminal Block (Screw) , 1 x hardwire 5-wire (3PH + N + G) , 1 x hardwire 4-wire (3PH + G)
Lead Acid expandable
Battery Form Factor
Internal
Batteries Qty
2 (installed) / 4 (max)
Run Time (Up To)
18.5 min at full load
Ethernet 10/100, RS-232
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS
Bolt down brackets
55.9 cm x 81.3 cm x 150 cm
1 year warranty
UPS - external
Battery Enclosure Type
Internal
Output Connectors
UPS Technology
On-line
Input Voltage
AC 380/400/415 V
Input Voltage Range
AC 304 - 477 V
Frequency Provided
47 - 53 Hz
Input Wiring
3-phase
Frequency Required
47 - 70 Hz
Input Connectors
Output Voltage
AC 380/400/415 V ± 5% - 47 - 53 Hz
Power Capacity
8 kW / 10000 VA
Output Waveform
Sinewave
Surge Suppression
Circuit Protection
Circuit breaker
Expandable
Quantity
Lead Acid
Voltage Provided
192 V
Run Time (Up To)
Recharge Time
5 hours
Remote Management Interface
1 x management (Ethernet) - RJ-45 , 1 x EPO (emergency power off) , 1 x management (RS-232) - 9 pin D-Sub (DB-9)
Expansion Slots
1 (total) / 0 (free) x SmartSlot
Bolt down brackets
Audible alarm, emergency power off, LCD display, Parallel Capability, built-in maintenance bypass, built-in static bypass
C-Tick, ISO 9001, IEC 61000-3-2, IEC 61000-3-3, ISO 14001, IEC 60529 IP20, EN 50091-2, IEC 62040-3
Software Included
Drivers & Utilities
Limited warranty - 1 year , Installation , Technical support - training
0 - 95%
Sound Emission
54 dBA
55.9 cm
81.3 cm
150 cm
415 kg
Shipping Width
65 cm
Shipping Depth
106 cm
Shipping Height
164 cm
Shipping Weight
446 kg
Scroll to top
