BT.com
Wishlist
APC Smart-UPS SRT 8000VA 230V
£4,650.46
£4,650.46
Add to wishlist
Delivery
Standard Due date unavailable
Provides pure sine wave output which is recommended by server manufacturers using active power factor corrected (PFC) power supplies. Safety agency tested and approved means that you can deploy Smart-UPS with confidence that they meet or exceed the industry's most rigorous standards.
Network grade power conditioning protects from damaging surges and disruptive noise. The double conversion architecture provides tight voltage regulation, frequency regulation, and zero transfer time to battery during power events.
Intelligent battery management, pioneered by APC, maximizes battery performance and life through intelligent, precision temperature compensated charging. Automatic self tests insure battery reliability and warn customers in advance of battery replacement. Convenient, easy to connect, hot-swappable battery modules provide battery replacement without powering down.
APC Smart-UPS SRT 8000VA - UPS - 8000 Watt - 8000 VA
UPS - rack-mountable / external
Rack Size
6U
111.82 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 3%
Power Capacity
8000 Watt / 8000 VA
Input Connectors
Hardwire 5-wire (3PH + N + G), hardwire 3-wire (1PH + N + G)
Output connectors
6 x power IEC 60320 C13 , 4 x power IEC 60320 C19 , 1 x hardwire 3-wire (HN + G) , 3 x IEC connector
Lead Acid
Run Time (Up To)
5.3 min at full load
Ethernet 10/100, USB
26.3 cm x 71.5 cm x 43.2 cm
3 years warranty
Height (Rack Units)
6U
UPS Technology
On-line
Input Voltage
AC 230 V
Frequency Provided
50/60 Hz
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
AC 230 V ± 3% - 50/60 Hz
Power Capacity
8000 Watt / 8000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 Joules
Efficiency
98%
Lead Acid
Run Time (Up To)
5.3 min at full load , 14.8 min at half load
Recharge Time
3 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
1 x management (Ethernet) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off) , 1 x serial - RJ-45
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Audible alarm, LCD display
C-Tick, VDE, IEC 60950, EN 50091-2, RoHS, EN 50091-1, REACH, EN 62040-2, IP20, EAC
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95% (non-condensing)
Sound Emission
55 dBA
26.3 cm
71.5 cm
43.2 cm
111.82 kg
Shipping Width
60 cm
Shipping Depth
254 cm
Shipping Height
46.1 cm
Shipping Weight
126.82 kg
Accessories
C2G 2M DB9 M/F ALL LINES EXT CBL BLK
Quicklinx: 63SX | In Stock
£4.51
C2G 3m DB9 M/F Extension Cable - Black
Quicklinx: 681W | In Stock
£5.35
C2G 5m DB9 M/F Extension Cable - Black
Quicklinx: 681X | In Stock
£7.29
C2G 7m DB9 M/F Extension Cable - Black
Quicklinx: 681Y | In Stock
£9.57
£4.95
£3.82
£11.91
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.50
£54.00
Scroll to top
