BT.com
Wishlist
APC Smart-UPS SC 450VA 1U
£227.02
More than 50 in stock
£227.02
Add to wishlist
Delivery
Standard 1-3 working days
APC Smart-UPS SC is the perfect protection for the IT resources of your growing business. Manageable and cost effective, APC Smart-UPS SC is designed for use by small and medium companies looking to protect networking equipment, providing both power and data-line protection. Included PowerChute Business Edition management software allows you to configure safe system shutdowns and take advantage of advanced UPS management features like automated risk assessments and runtime capacity calculations. (All major operating systems supported). Communications are through your server's standard serial port. When you are ready to take your business to the next level you can use the same software environment found on Smart-UPS SC to seamlessly manage other Smart-UPS models, allowing you to grow your IT infrastructure without having to replace your software or retrain your administrators. Built on the same standards as the award winning Smart-UPS UPS, the Smart-UPS SC is the UPS to start your business with.
APC Smart-UPS SC 450VA - UPS - 280 Watt - 450 VA
UPS - rack-mountable
Rack Size
1U
10.2 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 5%
Power Capacity
280 Watt / 450 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
4 x power IEC 60320 C13
Lead Acid
Battery Form Factor
Plug-in module
Run Time (Up To)
5.9 min at full load
RS-232
43.2 cm x 38.3 cm x 4.4 cm
2 years warranty
Battery Enclosure Type
Plug-in module
Height (Rack Units)
1U
Grey
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
47 - 63 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V ± 5% - 47 - 63 Hz
Power Capacity
280 Watt / 450 VA
Dataline Surge Protection
Network/phone line - RJ-45/RJ-11
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Surge Energy Rating
320 Joules
Lead Acid
Run Time (Up To)
Remote Management Interface
RS-232
1 x management (RS-232) - 9 pin D-Sub (DB-9)
Serial cable - external
Rack Mounting Kit
Included
Audible alarm, LED display
C-Tick, GOST, PCBC, VDE, EN 50091-2
Software Included
Drivers & Utilities
0 - 95%
43.2 cm
38.3 cm
4.4 cm
10.2 kg
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Q: about noise
Reviewed by boolve on 27/01/2008
I have question. Are this UPS build in fan? All rack mount APC UPS with noise level ~ 34dBa. All time this fan is on?
Scroll to top
