BT.com
Wishlist
APC Smart-UPS SC 420VA 260W
£139.66
More than 50 in stock
£139.66
Add to wishlist
Delivery
Standard 1-3 working days
APC Smart-UPS protects your data by supplying reliable, network-grade power in either traditional Tower or Rack-optimized form factors for space constrained business critical applications. Award winning APC Smart-UPS is the perfect UPS for protecting business critical fileservers (Intel or UNIX based), minicomputers, network switches and hubs, Point of Sale, retail/bank back office and ATM's.
APC Smart-UPS SC 420VA - UPS - 260 Watt - 420 VA
UPS - external
9 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
260 Watt / 420 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
4 x power IEC 60320 C13
Lead Acid
Battery Form Factor
Plug-in module
Run Time (Up To)
5.5 min at full load
12 cm x 37 cm x 17 cm
2 years warranty
UPS - external
Battery Enclosure Type
Plug-in module
Grey
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V
Power Capacity
260 Watt / 420 VA
Dataline Surge Protection
Ethernet 10/100Base-TX - RJ-45
Surge Suppression
Surge Energy Rating
320 Joules
Lead Acid
Run Time (Up To)
1 x RS-232 - 9 pin D-Sub (DB-9)
Power cable - integrated - 1.8 m , Serial cable
Audible alarm
FCC Class B certified, CSA, NOM, UL 1449, UL 1778, FCC Part 15
Limited warranty - parts and labour - 2 years
0 - 95%
12 cm
37 cm
17 cm
9 kg
Scroll to top
