BT.com
Wishlist
APC Smart-UPS RT 8000VA 230V
Delivery
Standard Due date unavailable
APC Smart-UPS RT is a family of high-density, performance UPSs for voice and data networks, medical labs, and light industrial applications. 6U form factor allows standardization across multiple applications. High power internal chargers allow virtually unlimited additional matching battery packs to comply with aggressive runtime demands of business-critical systems. Customers with harsh power environments looking for extremely tight voltage and frequency regulation, internal bypass, and input power factor correction typical of double conversion online topology will get them in the Smart-UPS RT.
APC Smart-UPS RT 8000VA - UPS - 8000 VA
UPS - external
Rack Size
6U
110.9 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V ± 3%
Power Capacity
8000 VA
Input Connectors
2 x hardwire 5-wire (3PH + N + G)
Output connectors
1 x hardwire 3-wire (HN + G) , 4 x power IEC 60320 C13 , 4 x power IEC 60320 C19
Lead Acid
Batteries Qty
4 (installed) / 4 (max)
Ethernet 10/100
Remote Management Protocol
SNMP, HTTP
26.3 cm x 66.3 cm x 43.2 cm
2 years warranty
UPS - external
Height (Rack Units)
6U
UPS Technology
On-line
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 160 - 280 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 3% - 50/60 Hz
Power Capacity
8000 VA
Output Waveform
Sinewave
Surge Suppression
Quantity
Lead Acid
Remote Management Interface
Ethernet 10/100
SNMP, HTTP
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (Ethernet) - RJ-45
Expansion Slots
1 (total) / 0 (free) x SmartSlot
Serial cable - external
Audible alarm, emergency power off, LED indicators
C-Tick, GOST, EN 60950, EN 61000-3-2, UL 1449, VDE, EN55022 Class A, EN 50091-2, EN 50091-1
Software Included
Drivers & Utilities
0 - 95%
Sound Emission
55 dBA
26.3 cm
66.3 cm
43.2 cm
110.9 kg
Accessories
APC Rack Automatic Transfer Switch
Quicklinx: 53TD | In Stock
£560.72
Scroll to top
