BT.com
Wishlist
APC Smart-UPS RT 3000VA RM 230V
£1,827.25
£1,827.25
Add to wishlist
Delivery
Standard Due date unavailable
Customize UPS capabilities with management cards. Automatic internal bypass supplies utility power to the connected loads in the event of a UPS power overload or fault. Scalable run time allows additional run time to be quickly added as needed. Intelligent battery management maximizes battery performance, life, and reliability through intelligent, precision charging. Hot-swappable batteries ensure clean, uninterrupted power to protected equipment while batteries are being replaced.
APC Smart-UPS RT 3000VA RM - UPS - 2.1 kW - 3000 VA
UPS - rack-mountable
Rack Size
3U
54.6 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V ± 3%
Power Capacity
2.1 kW / 3000 VA
Input Connectors
3 x power IEC 60320 C20, power BS 1363, power CEE 7/7 (SCHUKO)
Output connectors
8 x power IEC 60320 C13 , 2 x power IEC 60320 C19
Lead Acid
Battery Form Factor
Plug-in module
Batteries Qty
1
Run Time (Up To)
14.1 min at full load
RS-232
43.2 cm x 66 cm x 13 cm
2 years warranty
Battery Enclosure Type
Plug-in module
Height (Rack Units)
3U
UPS Technology
On-line
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 160 - 280 V
Input Voltage Range (Adjustable)
AC 100 - 280 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 3% - 50/60 Hz
Power Capacity
2.1 kW / 3000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 Joules
Quantity
1
Lead Acid
Run Time (Up To)
Recharge Time
2.5 hours
Remote Management Interface
RS-232
1 x management (RS-232)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Power cable - 2.4 m , Serial cable - external
Rack Mounting Kit
Included
Audible alarm, emergency power off, internal bypass, LED indicators
CSA, VCCI, C-Tick, BSMI, GOST, EN 60950, EN 61000-3-2, JEON, UL 1778, VDE, EN55022 Class A, EN 50091-2, EN 50091-1
Software Included
Drivers & Utilities
0 - 95%
Sound Emission
55 dBA
43.2 cm
66 cm
13 cm
54.6 kg
Shipping Width
60.3 cm
Shipping Depth
98 cm
Shipping Height
34.7 cm
Shipping Weight
63.6 kg
Accessories
APC UPS Battery Pack
Quicklinx: 3R9K | In Stock
£1,047.06
APC Rack Automatic Transfer Switch
Quicklinx: 53TD | In Stock
£550.56
Scroll to top
