BT.com
Wishlist
APC Smart-UPS RT- 1000VA/700W Interface Port DB-9
APC Smart-UPS RT- 1000VA/700W...
£756.72
£756.72
Add to wishlist
Delivery
Standard Due date unavailable
APC Smart-UPS RT is a family of high-density, performance UPSs for voice and data networks, medical labs, and light industrial applications. Featuring double conversion on-line topology, the Smart-UPS RT protects your data by supplying reliable, network-grade power. An unlimited number of matching battery packs can be added to comply with aggressive runtime demands of "always on" business-critical systems. Rack-optimized models are an ideal choice for space constrained environments. With capacity up to 10kVA in a convenient rack-mountable 6U form, users can support power hungry blade servers or heavily loaded equipment racks. Customers looking for extremely tight voltage and frequency regulation, internal bypass, and input power factor correction will find them in the Smart-UPS RT.
APC Smart-UPS RT 1000VA RM - UPS - 700 Watt - 1000 VA
UPS - rack-mountable
Rack Size
2U
23 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
700 Watt / 1000 VA
Input Connectors
1 x power IEC 60320 C14
Lead Acid
Battery Form Factor
Plug-in module
Run Time (Up To)
10.2 min at full load
43.7 cm x 48.8 cm x 8.6 cm
2 years warranty
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
UPS Technology
On-line
Supported Battery Technology
Lead Acid
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 280 V
Input Voltage Range (Adjustable)
AC 100 - 280 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V
Power Capacity
700 Watt / 1000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Response Time
0 ns
Surge Energy Rating
420 Joules
Lead Acid
Run Time (Up To)
1 x management (RS-232) - 25 pin D-Sub (DB-25)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Serial cable - external
Rack Mounting Kit
Included
Emergency power off, audible alarm, Power Factor Correction (PFC)
FCC Class A certified, CSA, UL 1778
Software Included
Drivers & Utilities
Min Storage Temperature
-15 °C
Max Storage Temperature
45 °C
0 - 95%
43.7 cm
48.8 cm
8.6 cm
23 kg
Accessories
APC Network Management Card
Quicklinx: 567B | In Stock
£344.32
Scroll to top
