BT.com
Wishlist
APC Smart-UPS RM 1000VA USB & Serial - UPS - 640 Watt - 1000 VA
APC Smart-UPS RM 1000VA USB &...
£695.59
£695.59
Add to wishlist
Delivery
Standard 1-3 working days
APC Smart-UPS protects your data by supplying reliable, network-grade power in either traditional Tower or Rack-optimized form factors for space constrained business critical applications. Award winning APC Smart-UPS is the perfect UPS for protecting business critical fileservers (Intel or UNIX based), minicomputers, network switches and hubs, Point of Sale, retail/bank back office and ATM's. Rack Mount versions are the choice for rack optimized servers, server appliances, blade servers, other blade devices and rack-mounted network switches and hubs.
With included PowerChute management software for servers and workstations, IT administrators can provide safe system shutdown and advanced UPS management (all major operating systems are supported). Connectivity is through serial or USB port (USB not standard on all models). Additional manageability is available through the SmartSlot, an internal accessory slot that allows you to install optional accessories to enhance the performance of your UPS. Network connection with Web browser management and/or environmental monitoring, serial port expansion, and out-of-band management options are available. With pure sine-wave output ensuring compatibility with all connected devices, Intelligent Battery Management ensuring a highly available UPS and an advanced 16 segment bar graph display ensuring information and management, the Smart-UPS is a UPS you can count on.
UPS - rack-mountable
Rack Size
1U
22 kg
Input Voltage
AC 230 V
Output Voltage
AC 220/230/240 V
Power Capacity
640 Watt / 1000 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
4 x power IEC 60320 C13
Lead Acid
Run Time (Up To)
5.4 min at full load
43 cm x 66 cm x 4 cm
2 years warranty
Height (Rack Units)
1U
UPS Technology
Line interactive
Supported Battery Technology
Lead Acid
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V
Power Capacity
640 Watt / 1000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 Joules
Lead Acid
Run Time (Up To)
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB) - 4 pin USB Type B
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Serial cable - external , USB cable - external
Rack Mounting Kit
Included
LED display, audible alarm
C-Tick, GOST, PCBC, UL 1449, VDE
Software Included
Drivers & Utilities, APC PowerChute Smart-UPS Bundle
Limited warranty - parts and labour - 2 years
Min Storage Temperature
-15 °C
Max Storage Temperature
45 °C
0 - 95%
Humidity Range Storage
0 - 95%
43 cm
66 cm
4 cm
22 kg
Accessories
APC Network Management Card
Quicklinx: 567B | In Stock
£344.32
£309.84
APC UPS Network Management Card 2
Quicklinx: 64RK | In Stock
£194.14
Scroll to top
