BT.com
Wishlist
APC Smart-UPS C 1500VA LCD 230V
£494.55
£494.55
Add to wishlist
Delivery
Standard 1-3 working days
Green mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Pure sine wave output on battery simulates utility power to provide a high degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics. LCD status display provides key UPS status at a glance. It has multiple status indicators with load and battery bar graphs. Cold-start capable provides temporary battery power when the utility power is out. Temperature-compensated battery charging prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS C 1500VA LCD - UPS - 980 Watt - 1500 VA
UPS - external
24.09 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 5%
Power Capacity
980 Watt / 1500 VA
Input Connectors
1
Output connectors
8 x power IEC 60320 C13 , 2 x power
Lead Acid
Battery Form Factor
Internal
Batteries Qty
1
Run Time (Up To)
7 min at full load
RS-232, USB
17.1 cm x 43.9 cm x 21.9 cm
2 years warranty
UPS - external
Battery Enclosure Type
Internal
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 180 - 287 V
Input Voltage Range (Adjustable)
AC 170 - 300 V
Frequency Provided
47 - 53 / 57-63 Hz
Frequency Required
50/60 Hz
Input Connectors
1
Output Voltage
AC 230 V ± 5% - 47 - 53 / 57-63 Hz
Power Capacity
980 Watt / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
459 Joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
24 min at half load , 7 min at full load
Recharge Time
3 hours
Remote Management Interface
RS-232, USB
1 x management (USB) - 4 pin USB Type B , 1 x management (RS-232) - RJ-45
Power cable , USB cable - external
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), cold-start function, automatic shut down reset, automatic self-test, hot-swappable batteries
C-Tick, GOST, UL 1449, VDE, RoHS, REACH
Software Included
Drivers & Utilities
Limited warranty - parts and labour - 2 years
0 - 95%
Sound Emission
45 dBA
17.1 cm
43.9 cm
21.9 cm
24.09 kg
Shipping Width
32.8 cm
Shipping Depth
59.5 cm
Shipping Height
37.6 cm
Shipping Weight
27.23 kg
Scroll to top
