BT.com
Wishlist
APC Smart-UPS C 1000VA 2U Rack Mountable LCD 230V
Delivery
Standard Due date unavailable
Green mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Pure sine wave output on battery simulates utility power to provide a high degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics. LCD status display provides key UPS status at a glance. It has multiple status indicators with load and battery bar graphs. Cold-start capable provides temporary battery power when the utility power is out. Temperature-compensated battery charging prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS C 1000VA 2U LCD - UPS - 600 Watt - 1000 VA
UPS - rack-mountable
Rack Size
2U
20.52 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 5%
Power Capacity
600 Watt / 1000 VA
Input Connectors
1
Output connectors
4 x power IEC 60320 C13 , 1 x power
Lead Acid
Battery Form Factor
Internal
Batteries Qty
1
Run Time (Up To)
6 min at full load
USB
43.2 cm x 40.6 cm x 8.9 cm
2 years warranty
Battery Enclosure Type
Internal
Height (Rack Units)
2U
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 180 - 287 V
Input Voltage Range (Adjustable)
AC 170 - 300 V
Frequency Provided
57 - 63 Hz
Frequency Required
50/60 Hz
Input Connectors
1
Output Voltage
AC 230 V ± 5% - 57 - 63 Hz
Power Capacity
600 Watt / 1000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
459 Joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
16 min at half load , 6 min at full load
Recharge Time
3 hours
Remote Management Interface
USB
1 x management (USB) - 4 pin USB Type B
Power cable , USB cable - external
Rack Mounting Kit
Included
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), cold-start function, automatic shut down reset, automatic self-test, hot-swappable batteries
C-Tick, GOST, UL 1449, VDE, RoHS, REACH
Software Included
Drivers & Utilities
Limited warranty - parts and labour - 2 years
0 - 95%
Sound Emission
42 dBA
43.2 cm
40.6 cm
8.9 cm
20.52 kg
Shipping Width
59.4 cm
Shipping Depth
58.4 cm
Shipping Height
24.1 cm
Shipping Weight
22.33 kg
Scroll to top
