BT.com
Wishlist
APC Smart-UPS 2200VA LCD 230V
£823.60
38 in stock
£823.60
Add to wishlist
Delivery
Standard 1-3 working days
APC award-winning Smart-UPS is the most popular UPS in the world for servers, storage and networks. Trusted to protect critical data and equipment from power problems by supplying clean and reliable network-grade power.
In addition to legendary reliability and manageability, Smart-UPS have extremely high efficiency at low, medium and high load levels making them ideal for today's multi-core or virtualized servers that have varying load consumption.
Available in a variety of form factors (tower, rack mount, rack/tower convertible) there is a model for every application and budget. Smart-UPS models have long been considered the benchmark for all network and server UPS's. Smart-UPS feature a 16-segment LED display, extended range automatic voltage regulation (AVR), and pure sine wave output on battery.
Additional manageability options are available through the Smart-Slot interface, which is an internal slot for the installation of optional accessory cards.
Alphanumeric LCD (Liquid Crystal Display) Intuitive interface provides detailed and accurate information with the ability to configure locally.
Communication Ports - Serial, USB, and SmartSlot™ for accessory cards.
8 IEC320 C13 and 1 IEC320 C19 Outlets
Emergency Power Off (EPO) - Provides for remote UPS shut-off in the event of a fire or other emergency
Push Button Circuit Breaker enables quick recovery from overloads.
Network-grade Power - Provides most stable power conditions by filtering noise, automatic voltage regulation (AVR), and surge protection.
High Efficiency Green Mode Saves utility costs and reduces heat promoting longer component life.
Advanced Battery Management - Temperature-compensated charging extends life and advanced algorithms recommend replacement date.
APC Smart-UPS 2200 LCD - UPS - 1.98 kW - 2200 VA
UPS - external
48.8 kg
Input Voltage
AC 230 V
Output Voltage
AC 220/230/240 V ± 5%
Power Capacity
1.98 kW / 2200 VA
Input Connectors
Power IEC 60320 C20, power BS 1363, power CEE 7/16
Output connectors
8 x power IEC 60320 C13 , 1 x power IEC 60320 C19
Lead Acid
Batteries Qty
1
Run Time (Up To)
6.7 min at full load
RS-232, USB
19.7 cm x 54.4 cm x 43.5 cm
3 years warranty
UPS - external
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
47 - 53 / 57-63 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 5% - 47 - 53 / 57-63 Hz
Power Capacity
1.98 kW / 2200 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
365 Joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
6.7 min at full load , 24.1 min at half load
Recharge Time
3 hours
Remote Management Interface
RS-232, USB
1 x management (RS-232) , 1 x management (USB)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Serial cable - external , USB cable - external
Audible alarm, LCD display
C-Tick, UL 1449, VDE, EN 50091-2, RoHS Exemption 7b, EN 50091-1
Software Included
Drivers & Utilities
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
45 dBA
19.7 cm
54.4 cm
43.5 cm
48.8 kg
Shipping Width
38.1 cm
Shipping Depth
76.2 cm
Shipping Height
69.9 cm
Shipping Weight
61.9 kg
Accessories
£312.02
APC UPS Network Management Card 2
Quicklinx: 64RK | In Stock
£193.82
Scroll to top
