BT.com
Wishlist
APC Replacement Battery Cartridge
£310.94
3 in stock
£310.94
Add to wishlist
Delivery
Standard 3-5 working days
Hot-swappable batteries
Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
Includes: All required connectors, Battery recycling guide, Installation guide, Reusable packaging
APC Replacement Battery Cartridge #117 - UPS battery - Lead Acid
UPS battery
22.3 kg
Lead Acid
Battery Form Factor
Internal
Batteries Qty
1
20.3 cm x 58.4 cm x 7.6 cm
1 year warranty
P/N: SMX2000RMLV2UNC, SMX2000RMLV2UNC-TU, SMX2000RMLV2U-TU, SMX2200RMHV2U-5Y, SMX2200RMHV2U-B, SMX2200RMLV2U-TU, SMX3000RMHV2U, SMX3000RMHV2U D, SMX3000RMHV2U-5Y, SMX3000RMHV2UNC, SMX3000RMHV2UNC-B, SMX3000RMHV2U-TU, SMX3000RMLV2UNC-TU, SMX3000RMLV2U-RBC, SMX3000RMLV2U-RMC, SMX3000RMLV2U-TU
UPS battery
Battery Enclosure Type
Internal
Quantity
1
Lead Acid
Voltage Provided
120 V
RoHS Exemption 7b, REACH
Limited warranty - 1 year
0 - 95%
20.3 cm
58.4 cm
7.6 cm
22.3 kg
Shipping Width
39.3 cm
Shipping Depth
76.1 cm
Shipping Height
22.8 cm
Shipping Weight
25.2 kg
P/N: SMX2000RMLV2U, SMX2000RMLV2UNC, SMX2000RMLV2UNC-TU, SMX2000RMLV2U-TU, SMX2200RMHV2U-5Y, SMX2200RMHV2U-B, SMX2200RMLV2U, SMX2200RMLV2U-TU, SMX3000RMHV2U, SMX3000RMHV2U D, SMX3000RMHV2U-5Y, SMX3000RMHV2UNC, SMX3000RMHV2UNC-B, SMX3000RMHV2U-TU, SMX3000RMLV2U, SMX3000RMLV2UNC, SMX3000RMLV2UNC-TU, SMX3000RMLV2U-RBC, SMX3000RMLV2U-RMC, SMX3000RMLV2U-TU
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Damaged stock - Item is new but has packaging damage
Ref: 9DP8 036889
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£243.93
Ref: 9DP8 036890
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£243.93
Item condition Customer return - item has been repaired under warranty by the manufacturer
Ref: 9DP8 036159
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£45.66
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
