BT.com
Wishlist
APC Rack PDU Basic ZeroU 16A 230V (20)C13 & (4)C19;
APC Rack PDU Basic ZeroU 16A 230V...
£203.19
£203.19
Add to wishlist
Delivery
Standard Due date unavailable
APC offers a wide variety of Basic Rack Power Distribution Units (PDUs), which allow users to distribute power outlets to rack-mount equipment. Horizontal and vertical units are available as well as a variety of power inputs and outputs to fit most power environments. Basic Rack PDUs are InfraStruXure Certified and mount vertically, without tools in the rear channel of a NetShelter VX.
APC Basic Rack-Mount PDU - power distribution strip - 3680 Watt
Power distribution strip - rack-mountable
Cord Length
0.91 m
4.9 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
3680 Watt
Input Connectors
1 x power IEC 60309
Output connectors
20 x power IEC 60320 C13 , 4 x power IEC 60320 C19
5.6 cm x 4.4 cm x 161.9 cm
2 years warranty
P/N: AR3100, AR3150
Cord Length
0.91 m
Input Voltage
AC 230 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
1 x power IEC 60309
Output Voltage
AC 230 V 50/60 Hz
Max Electric Current
16 A
Power Capacity
3680 Watt
Power cable - external - 0.91 m
Rack Mounting Kit
Included
EN 60950, VDE
Limited warranty - parts and labour - 2 years , Limited warranty - replacement - 2 years
45 °C
Min Storage Temperature
-25 °C
Max Storage Temperature
65 °C
5 - 95%
Humidity Range Storage
5 - 95%
5.6 cm
4.4 cm
161.9 cm
4.9 kg
P/N: AR3100, AR3150
Scroll to top
