BT.com
Wishlist
APC Rack PDU 2G Switched ZeroU
£979.50
Hurry, only 2 left in stock!
£979.50
Add to wishlist
Delivery
Standard 1-3 working days
APC Switched Rack Power Distribution Units (PDUs) enable advanced, user-customizable power control and active monitoring. Remote outlet level controls allow power on/off functionality for power recycling to remotely reboot equipment and restrict unauthorized use of individual outlets. Power sequencing delays allow users to define the order in which to power up or down attached equipment. Avoid circuit overload during power recovery and extend uptime of critical equipment by prioritizing the load shedding. Current metering provides real-time remote monitoring of connected loads. Switched Rack PDUs include real power monitoring, a temperature/humidity sensor port, locking IEC receptacles, and low profile circuit breakers. User-defined alarms warn of potential circuit overloads before critical IT failures occur. Users can access, configure, and control Switched Rack PDUs through secure Web, SNMP, or Telnet Interfaces and is complimented by APC Centralized Management platforms using InfraStruxure Central, Capacity Manager and Change Manager.
APC Switched Rack PDU 2G Zero U - power distribution unit
Power distribution unit - rack-mountable
7 kg
Input Wiring
3-phase
Input Voltage
AC 400 V
Output Voltage
AC 208/230 V
Input Connectors
1 x power IEC 60309
Output connectors
21 x power IEC 60320 C13 , 3 x power IEC 60320 C19
Ethernet, RS-232, USB
Remote Management Protocol
SNMP, Telnet, HTTP
5.6 cm x 4.6 cm x 179.1 cm
2 years warranty
P/N: AR3100, AR3150, SMX3000RMHV2UNC
Input Voltage
AC 400 V
Input Wiring
3-phase
Input Connectors
1 x power IEC 60309
Output Voltage
AC 208/230 V
Max Electric Current
16 A
Remote Management Interface
SNMP, Telnet, HTTP
1 x management (Ethernet) - RJ-45 , 1 x management (RS-232) , 1 x management (USB)
Power cable - external - 1.83 m , Serial cable - external
Rack Mounting Kit
Included
LCD display, current meter, LED indicators
UL, cUL, EN 61000-3-2, ICES-003, VDE, EN 61000-3-3, EN55024, EN55022 Class A, RoHS, FCC Part 15 A, REACH
-5 °C
45 °C
5 - 95%
5.6 cm
4.6 cm
179.1 cm
7 kg
Shipping Width
16.5 cm
Shipping Depth
11.4 cm
Shipping Height
200.2 cm
Shipping Weight
8.95 kg
Scroll to top
