BT.com
Wishlist
APC Rack PDU 2G
APC Rack PDU 2G
£750.56
APC Rack PDU 2G
17 in stock
£750.56
Add to wishlist
Delivery
Standard 1-3 working days
APC Switched Rack Power Distribution Units (PDUs) enable advanced, user-customizable power control and active monitoring. Remote outlet level controls allow power on/off functionality for power recycling to remotely reboot equipment and restrict unauthorized use of individual outlets. Power sequencing delays allow users to define the order in which to power up or down attached equipment. Avoid circuit overload during power recovery and extend uptime of critical equipment by prioritizing the load shedding. Current metering provides real-time remote monitoring of connected loads. Switched Rack PDUs include real power monitoring, a temperature/humidity sensor port, locking IEC receptacles, and low profile circuit breakers. User-defined alarms warn of potential circuit overloads before critical IT failures occur. Users can access, configure, and control Switched Rack PDUs through secure Web, SNMP, or Telnet Interfaces.
APC Switched Rack PDU 2G Zero U - power distribution strip
Power distribution strip - rack-mountable
5.7 kg
Input Voltage
AC 200/208/230 V
Output Voltage
AC 230 V
Input Connectors
1 x power IEC 60309 16A
Output connectors
3 x power IEC 60320 C19 , 21 x power IEC 60320 C13
RS-232
Remote Management Protocol
SNMP, Telnet, HTTP
5.6 cm x 4.6 cm x 179 cm
2 years warranty
P/N: AR3100, AR3150, SMX3000RMHV2UNC
Input Voltage
AC 200/208/230 V
Input Voltage Range
AC 220 - 240 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V
Remote Management Interface
RS-232
SNMP, Telnet, HTTP
1 x management
Power cable - external - 3 m , Serial cable - external
Rack Mounting Kit
Included
LCD display
UL, cUL, EN 61000-3-2, EN55022, ICES-003, VDE, VCCI Class A ITE, EN 61000-3-3, EN55024, RoHS, FCC Part 15 A, PSE Mark, REACH
-5 °C
45 °C
5 - 95%
5.6 cm
4.6 cm
179 cm
5.7 kg
Shipping Width
16.5 cm
Shipping Depth
11.4 cm
Shipping Height
200 cm
Shipping Weight
8.6 kg
Scroll to top
