BT.com
Wishlist
APC Rack PDU 2G  Switched  0U  32A  230V  (21) C13 & (3) C19
APC Rack PDU 2G Switched 0U 32A...
£833.88
Hurry, only 3 left in stock!
£833.88
Add to wishlist
Delivery
Standard 1-3 working days
APC Switched Rack Power Distribution Units (PDUs) enable advanced, user-customizable power control and active monitoring. Remote outlet level controls allow power on/off functionality for power recycling to remotely reboot equipment and restrict unauthorized use of individual outlets. Power sequencing delays allow users to define the order in which to power up or down attached equipment. Avoid circuit overload during power recovery and extend uptime of critical equipment by prioritizing the load shedding. Current metering provides real-time remote monitoring of connected loads. Switched Rack PDUs include real power monitoring, a temperature/humidity sensor port, locking IEC receptacles, and low profile circuit breakers. User-defined alarms warn of potential circuit overloads before critical IT failures occur. Users can access, configure, and control Switched Rack PDUs through secure Web, SNMP, or Telnet Interfaces.
APC Switched Rack PDU 2G Zero U - power distribution strip
Power distribution strip - rack-mountable
8.6 kg
Input Voltage
AC 200/208/230 V
Input Connectors
1 x power IEC 60309 32A
Output connectors
3 x power IEC 60320 C19 , 21 x power IEC 60320 C13
RS-232
Remote Management Protocol
SNMP, Telnet, HTTP
5.6 cm x 4.6 cm x 183 cm
2 years warranty
P/N: AR3100, AR3150, SMX3000RMHV2UNC
Input Voltage
AC 200/208/230 V
Input Voltage Range
AC 220 - 240 V
Frequency Required
50/60 Hz
Input Connectors
Max Electric Current
32 A
Remote Management Interface
RS-232
SNMP, Telnet, HTTP
1 x management
Power cable - external - 3.05 m , Serial cable - external
Rack Mounting Kit
Included
LCD display, overload protection
EN 61000-3-2, EN55022, VDE, EN 61000-3-3, EN55024, RoHS, REACH
-5 °C
45 °C
5 - 95%
5.6 cm
4.6 cm
183 cm
8.6 kg
Shipping Width
16.5 cm
Shipping Depth
12.4 cm
Shipping Height
204 cm
Shipping Weight
10 kg
Scroll to top
