BT.com
Wishlist
APC Rack PDU, Metered, Zero U, 10A, 230V, (16) C13
APC Rack PDU, Metered, Zero U, 10A,...
£410.54
£410.54
Add to wishlist
Delivery
Standard Due date unavailable
APC's Metered Rack Power Distribution Units (PDUs) provide power distribution as well as equips on-site installers with the ability to monitor the aggregate current draw as equipment is connected to the unit. These Metered Rack PDUs also have alarm thresholds that when exceeded alert users of potential problems. These features help eliminate the possibility of an overloaded circuit.
APC Metered Rack PDU - power distribution strip
Power distribution strip - rack-mountable
Cord Length
3.05 m
Rack Size
0U
3.1 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Input Connectors
1 x power IEC 60320 C14
Output connectors
16 x power IEC 60320 C13
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS
5.6 cm x 4.5 cm x 124.5 cm
2 years warranty
P/N: AR3100, AR3150, SMX3000RMHV2UNC, SU1400RMXLI3U-3EW, SU1400RMXLIB3U, SU2200RMI3U.1, SU2200RMXLI3U-3EW, SU3000RMXLI3U-3EW, SU5000RMXLI5U-3EW, SUA2200RMXLI3U, SUA3000I, SUA3000R2IX322, SUA3000RMI, SUA750IX38, SURT3000XLI/S, SURT3000XLI-BRZ, SURT3000XLI-GLD, SURT3000XLI-SLV, SURT3000XLI-TU
Height (Rack Units)
0U
Cord Length
3.05 m
Input Voltage
AC 230 V
Input Voltage Range
AC 200 - 250 V
Input Voltage Margin
± 10%
Frequency Required
47 - 63 Hz ± 10%
Input Connectors
Output Voltage
AC 230 V
Max Electric Current
10 A
1 x LAN - RJ-45 , 1 x management - RJ-11
Power cable - integrated - 3.05 m
Rack Mounting Kit
Included
CISPR 22 Class A, EN 60950, IEC 61000-3-2, IEC 61000-3-3, VDE, IEC 60950, EN55024, EN55022 Class A
-5 °C
45 °C
5 - 95%
5.6 cm
4.5 cm
124.5 cm
3.1 kg
P/N: AR3100, AR3150, SMX3000RMHV2UNC, SU1400RMXLI3U, SU1400RMXLI3U U, SU1400RMXLI3U-1EW, SU1400RMXLI3U-2EW, SU1400RMXLI3U-3EW, SU1400RMXLIB3U, SU2200R3IBX120, SU2200RMI3U.1, SU2200RMXLI3U, SU2200RMXLI3U-1EW, SU2200RMXLI3U-2EW, SU2200RMXLI3U-3EW, SU3000R3IBX120, SU3000R3IX160, SU3000RMINET, SU3000RMINET-1EW, SU3000RMINET-2EW, SU3000RMINET-3EW, SU3000RMTX136, SU3000RMXLI3U, SU3000RMXLI3U-1EW, SU3000RMXLI3U-2EW, SU3000RMXLI3U-3EW, SU5000R51BX120, SU5000R5IBX120, SU5000R5TBX135, SU5000RMI5U, SU5000RMI5U-1EW, SU5000RMI5U-2EW, SU5000RMI5U-3EW, SU5000RMXLI5U, SU5000RMXLI5U-1EW, SU5000RMXLI5U-2EW, SU5000RMXLI5U-3EW, SU700RMI2U-1EW, SU700RMI2U-2EW, SU700RMI2U-3EW, SUA1000RMI2U, SUA1000RMI2U-3EW, SUA1000RMI2U-GLD, SUA1500RMI2U, SUA1500RMI2U-2EW, SUA1500RMI2U-SLV, SUA2200RMI2U-1EW, SUA2200RMI2U-SLV, SUA2200RMXLI3U, SUA3000I, SUA3000R2IX322, SUA3000RMI, SUA3000RMI2U, SUA3000RMI2U-1EW, SUA3000RMI2U-2EW, SUA3000RMI2U-3EW, SUA3000RMI2U-BRZ, SUA3000RMI2U-GLD, SUA3000RMI2U-SLV, SUA750IX38, SUA750RMI1U, SUA750RMI2U, SUA750RMI2U-3EW, SUA750RMI2U-BRZ, SUA750RMI2U-GLD, SUA750RMI2U-SLV, SURT3000XLI, SURT3000XLI/S, SURT3000XLI-BRZ, SURT3000XLI-GLD, SURT3000XLI-SLV, SURT3000XLI-TU
Scroll to top
