BT.com
Wishlist
APC Rack Automatic Transfer Switch
£603.42
£603.42
Add to wishlist
Delivery
Standard 1-3 working days
APC rack Automatic Transfer Switches (rack ATS) provide reliable, redundant power to single-corded equipment. The rack ATS has dual input power cords supplying power to the connected load. If the primary power source becomes unavailable, the rack ATS will seamlessly source power from the secondary source without interrupting critical loads. Networked units have built-in network connectivity, which allows for remote management via web, SNMP, or telnet interfaces.
APC Automatic Transfer Switch - redundant switch
Redundant switch - rack-mountable
Rack Size
1U
3.9 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Input Connectors
2 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13 , 1 x power IEC 60320 C19
Ethernet 10/100, RS-232
Remote Management Protocol
SNMP, Telnet, HTTP
43.2 cm x 22.9 cm x 4.4 cm
2 years warranty
P/N: DLA2200I, SMX3000RMHV2UNC, SUA2200R2ICH, SUA2200RMXLI3U, SUA2200XLI, SUA3000R2ICH, SUA3000XLI, SURT10000UXI, SURT15KRMXLI, SURT20KRMXLI, SURT6000RMXLI, SURT6000UXI, SURT6000XLI, SURT8000RMXLI, SURT8000UXI, SURTD3000RMXLI, SURTD3000UXI, SURTD3000XLI, SURTD5000RMXLI, SURTD5000UXI, SURTD5000XLI
Height (Rack Units)
1U
Input Voltage
AC 230 V
Frequency Required
47 - 63 Hz
Input Connectors
Output Voltage
AC 230 V
Max Electric Current
20 A
Remote Management Interface
SNMP, Telnet, HTTP
1 x management (RS-232) - RJ-11 , 1 x management (Ethernet) - RJ-45
Serial cable - external
Rack Mounting Kit
Included
Current meter
FCC Class A certified, EN55022 Class A, FCC Part 15
-5 °C
45 °C
5 - 95%
43.2 cm
22.9 cm
4.4 cm
3.9 kg
Shipping Width
60 cm
Shipping Depth
34.9 cm
Shipping Height
11.4 cm
Shipping Weight
5.7 kg
P/N: DLA2200I, SMX3000RMHV2UNC, SU2200RMXLI3U, SU2200UXINET, SU2200XLINET, SU3000INET, SU3000RMI3U, SU3000RMINET, SU3000UXINET, SU5000I, SU5000R5IBX120, SU5000R5TBX135, SU5000UXINET, SUA2200I, SUA2200R2ICH, SUA2200RMI2U, SUA2200RMXLI3U, SUA2200XLI, SUA3000I, SUA3000R2ICH, SUA3000RMI2U, SUA3000RMXLI3U, SUA3000XLI, SUM3000RMXLI2U, SURT10000RMXLI, SURT10000UXI, SURT10000XLI, SURT15KRMXLI, SURT20KRMXLI, SURT3000RMXLI, SURT3000XLI, SURT5000RMXLI, SURT6000RMXLI, SURT6000UXI, SURT6000XLI, SURT7500RMXLI, SURT8000RMXLI, SURT8000UXI, SURT8000XLI, SURTD3000RMXLI, SURTD3000UXI, SURTD3000XLI, SURTD5000RMXLI, SURTD5000UXI, SURTD5000XLI, SYA12K16I, SYA12K16RMI, SYA16K16RMI, SYA4K8RMI, SYA8K16RMI, SYA8K8RMI, SYH2K6RMI, SYH4K6RMI, SYH6K6RMI
Scroll to top
