BT.com
Wishlist
APC Rack ATS, 2U 230V, 32A, IEC309-32A In, (16)C13, (2)C19 Out
APC Rack ATS, 2U 230V, 32A,...
£755.05
30 in stock
£755.05
Add to wishlist
Delivery
Standard 1-3 working days
APC rack Automatic Transfer Switches (rack ATS) provide reliable, redundant power to single-corded equipment. The rack ATS has dual input power cords supplying power to the connected load. If the primary power source becomes unavailable, the rack ATS will seamlessly source power from the secondary source without interrupting critical loads. Networked units have built-in network connectivity, which allows for remote management via web, SNMP, or Telnet interfaces.
APC Automatic Transfer Switch - redundant switch
Redundant switch - rack-mountable
Rack Size
2U
6.9 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Input Connectors
2 x power IEC 60309 32A
Output connectors
16 x power IEC 60320 C13 , 2 x power IEC 60320 C19
Ethernet, RS-232
Remote Management Protocol
SNMP, Telnet, HTTP
43.2 cm x 23.6 cm x 88 cm
2 years warranty
Height (Rack Units)
2U
Input Voltage
AC 230 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V
Max Electric Current
32 A
Remote Management Interface
Ethernet, RS-232
SNMP, Telnet, HTTP
1 x management (RS-232) - RJ-11 , 1 x management (Ethernet) - RJ-45
2 x power cable - 2.44 m , Serial cable - external
Rack Mounting Kit
Included
Current meter, overload protection
EN55022 Class A, RoHS Exemption 7b, FCC Part 15 A
-5 °C
45 °C
5 - 95%
43.2 cm
23.6 cm
88 cm
6.9 kg
Shipping Width
61.3 cm
Shipping Depth
35.6 cm
Shipping Height
18.4 cm
Shipping Weight
9.4 kg
Scroll to top
