BT.com
Wishlist
APC ProtectNet Surge Protector
£24.74
12 in stock
£24.74
Add to wishlist
Delivery
Standard 3-5 working days
Data line surges make up an overwhelming majority of all surge-induced damages where the equipment was thought to be already protected but had a back door such as a modem line unprotected. Network interface cards, in particular, can be destroyed by relatively mild spikes.
According to Ethernet standards (IEEE 802.3), non-AC network electrical hazards include: direct contact between components and power or lightning circuits, static charge buildup on cables and component, high-energy transients coupled onto the local cabling system (those induced by other cables which are installed in the general proximity of network cables or lightning within a mile radius) and potential differences (even from building to building, between safety grounds to which components are connected).
APC ProtectNet - surge protector
Surge protector - external
0.1 kg
4.7 cm x 2.8 cm x 10.4 cm
Beige
Dataline Surge Protection
Ethernet 10/100/1000Base-T - RJ-45
Surge Suppression
Surge Response Time
1 ns
Patch cable - external - 0.2 m
Limited warranty - lifetime
-15 °C
65 °C
0 - 95%
4.7 cm
2.8 cm
10.4 cm
0.1 kg
Scroll to top
