BT.com
Wishlist
APC ProtectNet 9-pin Surge Suppressor
APC ProtectNet 9-pin Surge...
£21.70
Hurry, only 1 left in stock!
£21.70
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
APC provides power protection, environmental control and site monitoring services that are designed to proactively identify and correct problems before downtime occurs. Over the years, APC has received more than 150 awards worldwide for reliability and innovation of solutions - more than any other UPS manufacturer. APC's solutions are accepted as "best-of-breed" across the globe. You deserve the legendary reliability and peace of mind that only APC can provide.
APC ProtectNet - surge protector
Surge protector - external
60 g
Input Connectors
1 x 9 pin D-Sub (DB-9)
Output connectors
3.6 cm x 1.5 cm x 7.6 cm
Beige
Input Connectors
Surge Suppression
Surge Response Time
1 ns
Clamping Level
40 V
Circuit Protection
Circuit breaker
1 x RS-232 - 9 pin D-Sub (DB-9)
1 x serial - RS-232 - 9 pin D-Sub (DB-9)
15 °C
45 °C
0 - 95%
3.6 cm
1.5 cm
7.6 cm
60 g
Scroll to top
