BT.com
Wishlist
APC Power Saving Back-UPS Pro 900
£180.84
14 in stock
£180.84
Add to wishlist
Delivery
Standard 1-3 working days
The Back-UPS Pro provides abundant battery backup power, so you can work through medium and extended length power outages. It safeguards your equipment against damaging surges and spikes that travel along utility and data lines. And it features automatic voltage regulation (AVR), which instantly adjusts high and low voltages to safe levels, so you can work indefinitely during brownouts and overvoltages.
The Back-UPS Pro also includes unique "green" features, like power-saving outlets that automatically turn off idle peripherals. A high efficiency charging system and "AVR Bypass" also reduce power consumption. With the rest of the Back-UPS Pro's standard features, this is the perfect unit to protect your productivity from the constant threat of bad power and lost data.
Includes: CD with software, Qty 2 - Detachable 1.8 m IEC power cords, USB cable, User Manual, Warranty card
APC Back-UPS Pro 900 - UPS - 540 Watt - 900 VA
UPS - external
11.7 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
540 Watt / 900 VA
Input Connectors
1 x power IEC 60320
Output connectors
4 x power IEC 60320 (UPS and surge) , 4 x power IEC 60320 (surge)
Lead Acid
Battery Form Factor
Internal
10 cm x 38.2 cm x 25 cm
UPS - external
Battery Enclosure Type
Internal
UPS Technology
Line interactive
Input Voltage
AC 230 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
1 x power IEC 60320
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
540 Watt / 900 VA
Dataline Surge Protection
Phone line - RJ-11 , Ethernet 10/100Base-TX - RJ-45
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Lead Acid
Power cable - external - 1.8 m
Audible alarm, LCD display
C-Tick, GOST, GS, NEMKO, A-Tick
Software Included
APC PowerChute Personal Edition
10 cm
38.2 cm
25 cm
11.7 kg
Shipping Width
22.5 cm
Shipping Depth
48.9 cm
Shipping Height
33.3 cm
Shipping Weight
12.8 kg
Scroll to top
