BT.com
Wishlist
APC Power Saving Back-UPS Pro 1200
£288.10
30 in stock
£288.10
Add to wishlist
Delivery
Standard 1-3 working days
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Battery failure notification provides early-warning fault analysis on batteries enabling timely preventive maintenance. Reserves power capacity and run time for connected equipment that require battery back-up while providing surge only protection for less critical equipment.
Cold-start capable provides temporary battery power when the utility power is out. Hot-swappable batteries ensure clean, uninterrupted power to protected equipment while batteries are being replaced. Dataline surge protection provides protection of connected equipment from power surges on the data lines.
Includes: CD with software, Qty 2 - Detachable 2.0 m IEC power cords, Telephone Cable, USB cable, User Manual, Warranty card
APC Back-UPS Pro 1200 - UPS - 720 Watt - 1200 VA
UPS - external
11.6 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
720 Watt / 1200 VA
Input Connectors
Power IEC 60320 C14
Output connectors
5 x power IEC 60320 C13 (UPS and surge) , 5 x power IEC 60320 C13 (surge)
Lead Acid
Run Time (Up To)
7.6 min at full load
USB
11.2 cm x 38.2 cm x 30.2 cm
2 years warranty (European Union - 3 years)
UPS - external
Input Voltage
AC 230 V
Input Voltage Range
AC 186 - 284 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Power IEC 60320 C14
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
720 Watt / 1200 VA
Dataline Surge Protection
Network - RJ-45 , Phone line - RJ-11
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Surge Energy Rating
445 Joules
Lead Acid
Run Time (Up To)
7.6 min at full load , 19.9 min at half load
Recharge Time
8 hours
Remote Management Interface
USB
1 x management (USB)
USB cable - external
Audible alarm, LCD display
TUV, GOST, GS, RoHS, A-Tick
0 - 95%
Sound Emission
45 dBA
11.2 cm
38.2 cm
30.2 cm
11.6 kg
Shipping Width
23.8 cm
Shipping Depth
48.8 cm
Shipping Height
38.7 cm
Shipping Weight
13.2 kg
Scroll to top
