BT.com
Wishlist
APC Power-Saving Back-UPS ES 8 Outlet 700VA 230V
APC Power-Saving Back-UPS ES 8...
£92.66
More than 50 in stock
£92.66
Add to wishlist
Delivery
Standard 1-3 working days
The Back-UPS ES offers affordable battery backup and surge protection for home computers. With enough power outlets to protect your entire system, built-in phone/fax/modem line (DSL compatible) protection and easy-to-install safe system shutdown software all make this power protection solution the best value for home and home office computers.
APC Back-UPS ES 700 - UPS - 405 Watt - 700 VA
UPS - external
6.9 kg
United Kingdom
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
405 Watt / 700 VA
Input Connectors
1 x power BS 1363
Output connectors
4 x power BS 1363 (surge) , 4 x power BS 1363 (UPS and surge)
Lead Acid
Battery Form Factor
Internal
Batteries Qty
1
Run Time (Up To)
3.5 min at full load
22.4 cm x 31.1 cm x 8.9 cm
3 years warranty
UPS - external
Battery Enclosure Type
Internal
United Kingdom
UPS Technology
Off-line
Input Voltage
AC 230 V
Frequency Provided
47 - 63 Hz
Frequency Required
50/60 Hz
Input Connectors
1 x power BS 1363
Output Voltage
AC 230 V 47 - 63 Hz
Power Capacity
405 Watt / 700 VA
Dataline Surge Protection
Network/phone line - RJ-45
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
Recharge Time
16 hours
Power cable - integrated - 1.8 m , Phone cable - external
Audible alarm, LED indicators
UL 1449, RoHS
Limited warranty - 3 years
0 - 95%
22.4 cm
31.1 cm
8.9 cm
6.9 kg
Shipping Width
27.9 cm
Shipping Depth
40 cm
Shipping Height
12.7 cm
Shipping Weight
7.8 kg
Scroll to top
