BT.com
Wishlist
APC Network Management Card With 2 Environment Monitor
APC Network Management Card With 2...
£344.89
More than 50 in stock
£344.89
Add to wishlist
Delivery
Standard 1-3 working days
APC UPS network management card allows for secure monitoring and control of an individual APC UPS via web browser, command line interface, or SNMP. Embedded technology provides exceptional reliability with notification features that inform you of problems as they occur.
APC Network Management Card 2 with Environmental Monitoring - remote management adapter
Remote management adapter
Plug-in module
Ports
10/100 Ethernet
12.1 cm x 11.4 cm x 3.8 cm
90 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
2 years warranty
Smart-UPS 1000 LCD, 1500 LCD, 2200 LCD, 3000 LCD, 750 LCD; Smart-UPS RM 3000VA USB & Serial; Smart-UPS X
Plug-in module
Ports
10/100 Ethernet
Wired
Cabling Type
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Remote Management Protocol
Telnet, SNMP 3, HTTPS, SSH
2048-bit encryption, E-mail alert, firmware upgradable, temperature sensor
1 x 100Base-TX - RJ-45
Compatible Slots
1 x SmartSlot
Temperature sensor
Encryption Algorithm
SSL
RoHS
Software Included
Drivers & Utilities
12.1 cm
11.4 cm
3.8 cm
90 g
APC Smart-UPS 1000 LCD, 1500 LCD, 2200 LCD, 3000 LCD, 750 LCD , APC Smart-UPS RM 3000VA USB & Serial , APC Smart-UPS X
Scroll to top
