BT.com
Wishlist
APC Netshelter SX Roof Fan Tray 208-230 VAC
APC Netshelter SX Roof Fan Tray...
£246.76
£246.76
Add to wishlist
Delivery
Standard Due date unavailable
The rack fan tray is a low cost solution that aids in heat removal from a Netshelter enclosure. The system easily installs into the top of the enclosure and expels heat from the roof of the rack. The fan trays are designed to promote bottom to top airflow within the enclosure.
APC Roof Fan Tray rack fan tray
Rack fan tray
AC 208/230 V
57.4 cm x 89.3 cm x 6 cm
8.4 kg
2 years warranty
NetShelter SX Enclosure with Sides
Rack fan tray
AC 208/230 V
57.4 cm
89.3 cm
6 cm
8.4 kg
VDE, UL 60950, CSA 22.2 No. 60950
APC NetShelter SX Enclosure with Sides
Scroll to top
