BT.com
Wishlist
APC Netshelter SX Roof Fan Tray 208-230 VAC 750mm
APC Netshelter SX Roof Fan Tray...
Free delivery
£396.28
Free delivery
Hurry, only 1 left in stock!
£396.28
Add to wishlist
Delivery
Standard 1-3 working days
The APC Rack Fan Tray is a low cost solution that aids in heat removal from a Netshelter Enclosure. The system easily installs into the top of the enclosure and expels heat from the roof of the rack. The ACF504 fan tray promotes bottom to top airflow for a Netshelter SX enclosure in zero U of space. Cools by exhausting heat out of the roof of the rack.
This product is designed for Netshelter SX 750 mm.
APC Roof Fan Tray rack fan tray
Rack fan tray
AC 208/230 V
72.4 cm x 89.3 cm x 6 cm
10.2 kg
2 years warranty
NetShelter SX
Rack fan tray
AC 208/230 V
72.4 cm
89.3 cm
6 cm
10.2 kg
UL 60950, CSA 22.2 No. 60950
APC NetShelter SX
Scroll to top
