BT.com
Wishlist
APC NetBotz Room Monitor 355
£1,129.05
£1,129.05
Add to wishlist
Delivery
Standard Due date unavailable
The NetBotz 300 offers the best value for security and environmental monitoring over the network. An integrated camera allows video surveillance and monitoring to record human activity. It provides temperature, humidity, door contact, dry contact, spot leak, vibration, and smoke monitoring. Additional features like integration with InfraStruXure Central, Power over Ethernet, and user-defined alerts make the NetBotz 300 the perfect unit to protect your IT assets from security and environmental threats. The NetBotz 300 can be used in network closets to data centers, but it is commonly installed in network closets and server rooms.
NetBotz Room Monitor 355 features integrated camera and sensors (temperature, humidity, airflow, dewpoint, camera motion). It supports up to 4 universal sensors.
NetBotz Room Monitor 355 - network surveillance camera - with 120/240V PoE Injector
Network surveillance camera - fixed
Bundled with
17 cm x 9.5 cm x 21 cm
650 g
Wired
Ethernet 10Base-T/100Base-TX
Voltage
PoE
2 years warranty
Environmental Parameters (operating)
0 °C - 45 °C
Wired
17 cm
9.5 cm
21 cm
650 g
Bundled with
Camera
- fixed
Network Interface
Network Protocols
DHCP, DNS, HTTP, SMTP, TCP/IP, SOCKS
Alarm Inputs Qty
4
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
Wall mount kit
ICES-003, VCCI Class A ITE, FCC Part 15 A, C-Tick Class A
Power Requirements
PoE
45 °C
Scroll to top
