BT.com
Wishlist
APC MGE Galaxy 3500 40kVA 400V with 4 Battery Modules  Start-up
APC MGE Galaxy 3500 40kVA 400V with...
£11,481.80
£11,481.80
Add to wishlist
Delivery
Standard Due date unavailable
MGE Galaxy 3500 offers centralized 3 phase power protection with the reliability of the MGE product family. Ideal for commercial and technical facilities as well as industrial applications, the MGE Galaxy 3500 includes dual-mains input, automatic and maintenance bypasses, and scalable runtime with hot-swappable batteries for increased availability. The parallel capability for redundancy and capacity, and extended run battery frames provide increased flexibility. Low cost of ownership is achieved through best-in-class efficiency and a reduction in rating of electrical infrastructure - wires, transformers, and generators. The built in network management card with temperature monitoring provides remote monitoring and management through a simple web/SNMP interface. Serviceability is greatly enhanced by user-replaceable batteries, front access servicing. All these features make the MGE Galaxy 3500 the easiest UPS in its class to deploy, manage and maintain.
MGE Galaxy 3500 with 4 Battery Modules - UPS - 32 kW - 40000 VA
UPS - external
Output Connectors
3 x Terminal Block (Screw), hardwire 4-wire (3PH + G), hardwire 5-wire (3PH + N + G)
662 kg
Input Wiring
3-phase
Input Voltage
AC 380/400/415 V
Output Voltage
AC 380/400/415 V ± 5%
Power Capacity
32 kW / 40000 VA
Input Connectors
Hardwire 5-wire (3PH + N + G)
Output connectors
1 x hardwire 4-wire (3PH + G) , 1 x hardwire 5-wire (3PH + N + G) , 1 x Terminal Block (Screw)
Lead Acid expandable
Batteries Qty
4
Run Time (Up To)
5.5 min at full load
RS-232
Remote Management Protocol
SNMP, HTTP
Bolt down brackets
52.3 cm x 83.8 cm x 149 cm
1 year warranty
UPS - external
Output Connectors
UPS Technology
On-line
Input Voltage
AC 380/400/415 V
Input Voltage Range
AC 304 - 477 V
Input Voltage Range (Adjustable)
AC 340 - 460 V
Frequency Provided
47 - 53 Hz
Input Wiring
3-phase
Frequency Required
40 - 70 Hz
Input Connectors
Output Voltage
AC 380/400/415 V ± 5% - 47 - 53 Hz
Power Capacity
32 kW / 40000 VA
Output Waveform
Sinewave
Expandable
Quantity
4
Lead Acid
Run Time (Up To)
Recharge Time
5 hours
Remote Management Interface
RS-232
SNMP, HTTP
1 x management (RS-232) , 1 x EPO (emergency power off)
Expansion Slots
SmartSlot
Bolt down brackets
Serial cable - external
Audible alarm, emergency power off, LCD display, built-in maintenance bypass, built-in static bypass
ISO 9001, IEC 61000-3-2, IEC 61000-3-3, ISO 14001, EN 50091-2, IEC 62040-3, IEC 62040-1-1
Software Included
Drivers & Utilities
Limited warranty - 1 year
0 - 95%
Sound Emission
55 dBA
52.3 cm
83.8 cm
149 cm
662 kg
Shipping Width
65 cm
Shipping Depth
106 cm
Shipping Height
164 cm
Shipping Weight
692 kg
Scroll to top
