BT.com
Wishlist
APC Metered Rack PDU AP7853 ZeroU - power distribution strip
APC Metered Rack PDU AP7853 ZeroU -...
£416.25
£416.25
Add to wishlist
Delivery
Standard 1-3 working days
The American Power Conversion (APC) Metered Rack Power Distribution Unit (PDU) distributes power to devices in the rack. It has a sensor that measures the current that it and its attached devices use. It can be monitored through Web, Telnet, SNMP, SSH, or InfraStruXureManager interfaces.
Power distribution strip - rack-mountable
Cord Length
3.1 m
Rack Size
0U
5.7 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Input Connectors
1 x power IEC 60309
Output connectors
4 x power IEC 60320 C19 , 20 x power IEC 60320 C13
Remote Management Protocol
SNMP, Telnet, HTTP
5.6 cm x 4.4 cm x 161.9 cm
P/N: AR3100
Height (Rack Units)
0U
Cord Length
3.1 m
Input Voltage
AC 230 V
Input Voltage Margin
± 10%
Frequency Required
47 - 63 Hz ± 10%
Input Connectors
1 x power IEC 60309
Output Voltage
AC 230 V
Max Electric Current
32 A
SNMP, Telnet, HTTP
Power cable - integrated - 3.1 m
EN 61000-3-2, IEC 61000-3-2, IEC 61000-3-3, VDE, EN 61000-3-3, EN55024, EN55022 Class A, CISPR 22
-5 °C
45 °C
5 - 95%
5.6 cm
4.4 cm
161.9 cm
5.7 kg
P/N: AR3100
Scroll to top
