BT.com
Wishlist
APC Metered Rack PDU 1U 2.5m
£380.32
£380.32
Add to wishlist
Delivery
Standard Due date unavailable
The aggregate current draw per power distribution unit is displayed on the unit via a digital display. The local digital display helps installers avoid overloaded circuits by providing a visible warning when the current draw is close to the maximum amperage draw of the strip. Define alarm thresholds in order to avoid overloaded circuits. Network and visual alarms inform the user of possible problems. Load Indicator indicates overload and warning conditions based on the user-defined alarm thresholds. Alerts users of potential overloaded circuits. Includes horizontal, vertical, and tool less-mount varieties. Puts power where it is needed most - in the racks near the equipment. Supply power from one branch whip to multiple pieces of equipment, conveniently powering rack-mount equipment. Saves time and money during installation by using one branch whip and standard connections. Product family includes a variety of input and output connections to distribute 120V, 208V, or 230V power to multiple outlets. Having a variety of inputs and outputs allow users to adapt to varying power requirements. APC offers units that bring up to 14.4kW using a single branch whip.
APC Metered Rack PDU - power distribution strip
Power distribution strip - rack-mountable
Cord Length
2.5 m
Output Connectors
8 x power IEC 60320 C13
Rack Size
1U
1.7 kg
Input Voltage
AC 200/208/230 V
Output Voltage
AC 208/230 V
Input Connectors
1 x power IEC 60320 C20
Output connectors
Ethernet
Remote Management Protocol
SNMP, Telnet, HTTP
44.4 cm x 10.2 cm x 4.4 cm
2 years warranty
P/N: AR3100, AR3150
Height (Rack Units)
1U
Cord Length
2.5 m
Output Connectors
Input Voltage
AC 200/208/230 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 208/230 V
Max Electric Current
15 A
Circuit Protection
Circuit breaker
Remote Management Interface
Ethernet
SNMP, Telnet, HTTP
1 x management - RJ-45
Power cable - 2.5 m
Rack Mounting Kit
Included
Current meter
FCC Class A certified, CSA, UL, VCCI, C-Tick, GOST, cUL, ICES-003, VDE, UL 60950, FCC Part 15
-5 °C
45 °C
5 - 95%
44.4 cm
10.2 cm
4.4 cm
1.7 kg
Shipping Width
47 cm
Shipping Depth
33.7 cm
Shipping Height
6.4 cm
Shipping Weight
2.9 kg
P/N: AR3100, AR3150
Scroll to top
