BT.com
Wishlist
APC Generic SYMMETRA LX 4KVA POWER MOD
APC Generic SYMMETRA LX 4KVA POWER...
£1,153.10
Hurry, only 1 left in stock!
£1,153.10
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Monday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
APC sets the standard in its industry for quality, innovation and support. Its comprehensive solutions, which are designed for both home and corporate environments, improve the manageability, availability and performance of sensitive electronic, network, communications and industrial equipment of all sizes. The mission of APC is to improve the manageability, availability, and performance of information and communication systems through rapid development and delivery of innovative solutions to real customer problems.
APC Symmetra Power Module - UPS - 2.8 kW - 4000 VA
UPS - plug-in module
Rack Size
4U
15 kg
Input Voltage
AC 230/400 V
Output Voltage
AC 230 V
Power Capacity
2.8 kW / 4000 VA
25 cm x 56 cm x 15 cm
2 years warranty
P/N: SYA12K16I-3HAVL, SYA12K16I-5AVL, SYA12K16I-5HAVL, SYA12K16IXR-3AVL, SYA12K16IXR-3HAVL, SYA12K16IXR-5AVL, SYA12K16IXR-5HAVL, SYA16K16IXR-3HAVL, SYA16K16IXR-5HAVL, SYA16K16RMI-3HAVL, SYA16K16RMI-5HAVL, SYA4K8RMI-3HAVL, SYA4K8RMI-5HAVL, SYA8K16RMI/2, SYA8K16RMI-3HAVL, SYA8K16RMI-5HAVL
Height (Rack Units)
4U
Input Voltage
AC 230/400 V
Input Voltage Range
AC 155/276 - 290/480 V
Frequency Required
45 - 65 Hz
Output Voltage
AC 230 V
Power Capacity
2.8 kW / 4000 VA
C-Tick, EN 60950, VDE, IEC 60950, EN55024, EN55022 Class A, EN 50091-2
0 - 95%
25 cm
56 cm
15 cm
15 kg
P/N: SYA12K16I, SYA12K16I-3AVL, SYA12K16I-3HAVL, SYA12K16I-3XW, SYA12K16I-5AVL, SYA12K16I-5HAVL, SYA12K16I-5XW, SYA12K16I-TU, SYA12K16IXR, SYA12K16IXR-3AVL, SYA12K16IXR-3HAVL, SYA12K16IXR-3XW, SYA12K16IXR-5AVL, SYA12K16IXR-5HAVL, SYA12K16IXR-5XW, SYA16K16IXR, SYA16K16IXR-3AVL, SYA16K16IXR-3HAVL, SYA16K16IXR-3XW, SYA16K16IXR-5AVL, SYA16K16IXR-5HAVL, SYA16K16IXR-5XW, SYA16K16RMI, SYA16K16RMI-3AVL, SYA16K16RMI-3HAVL, SYA16K16RMI-3XW, SYA16K16RMI-5AVL, SYA16K16RMI-5HAVL, SYA16K16RMI-5XW, SYA4K8RMI, SYA4K8RMI-3AVL, SYA4K8RMI-3HAVL, SYA4K8RMI-3XW, SYA4K8RMI-5AVL, SYA4K8RMI-5HAVL, SYA4K8RMI-5XW, SYA8K16RMI, SYA8K16RMI/2, SYA8K16RMI-3AVL, SYA8K16RMI-3HAVL, SYA8K16RMI-3XW, SYA8K16RMI-5AVL, SYA8K16RMI-5HAVL, SYA8K16RMI-5XW
Scroll to top
