Click to visit BT.com
BT.com
Wishlist
APC Cable Trough 750mm
Quicklinx: 79F1WS00
Mfr#: AR8571
11 in stock
£74.91
Safety protection against electric shock and reduction of EMI emissions - NetShelter Enclosures incorporate a series of ground studs within each enclosure, providing adequate means for grounding all loose sheet metal panels and/or internally rack-mounted equipment.
APC cable management trough
Cable management trough
74.7 cm x 31.7 cm x 19.1 cm
6.9 kg
2 years warranty
NetShelter SX
74.7 cm
31.7 cm
19.1 cm
6.9 kg
Mounting Kit
Included
UL, RoHS, REACH
APC NetShelter SX
APC Cable Trough 750mm Bundle deal on APC Cable Trough 750mm
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£84.90
saving £4.99
