BT.com
Wishlist
APC APC 17 Rack LCD Console Lite
£887.13
Hurry, only 2 left in stock!
£887.13
Add to wishlist
Delivery
Standard 1-3 working days
The Rack LCD Console features a 17" LCD panel, a full keyboard, and a touch pad in a rackmountable sliding housing. The Rack LCD Console is intended for use with compatible target devices (a KVM switch or server). The device is easily installed and minimizes support and maintenance costs, ensuring lower cost of ownership. The ultra-thin LCD screen, touchpad technology, and easy-to-install slide rails combine to form a high-quality, streamlined solution built for server management. The Rack LCD can be used in a variety of IT environments, from computer rooms to large data centers.
APC LCD Console - KVM console - 17"
KVM console - 17"
Keyboard, touchpad
Native Resolution
1280 x 1024 at 75 Hz
48.2 cm x 61.4 cm x 4.4 cm
Height (Rack Units)
1U
15.9 kg
United Kingdom
UL, C-Tick, GOST, EN 60950, NOM, VDE, IEC 60950, EN55024, EN55022 Class A, CCC, RoHS, FCC Part 15 A, REACH
2 years warranty
Display Type
KVM console / TFT active matrix
Diagonal Size
17"
Native Resolution
Controls & Adjustments
Brightness
Cable management cover
Height (Rack Units)
1U
15.9 kg
Input
Keyboard, touchpad
KVM
Max Resolution
1280 x 1024 @ 75 Hz
KVM (SPHD-18) , USB , USB (Type B) , Management (RJ-11)
1 x keyboard / mouse / video cable , 1 x video / USB cable , 1 x USB cable , 1 x data cable
Rack Mounting Kit
Included
United Kingdom
Power Supply
Internal
0 - 80% (non-condensing)
Scroll to top
