BT.com
Wishlist
APC AP7950 RACK PDU
Delivery
Standard 1-3 working days
APC's Switched Rack Power Distribution Units (PDUs) are premium solutions to many of the power management problems seen in today's IT environments. Some of the problems are unauthorized use of power outlets, locked-up equipment, in-rush current, overloaded circuits, and the need of remote access to power outlets in the rack. The Switched Rack PDUs address these problems through individual outlet control, power on and off delays, current monitoring, alarm thresholds, and network management. Individual outlet control allows users to turn outlets on, turn outlets off, or recycle power to equipment, which can reboot locked-up equipment and avoid unauthorized use of outlets. Power delays allow users to determine the order in which equipment is powered up or down. Utilizing the power delay feature will avoid in-rush current, which can cause overloads. Monitoring the current draw at the rack level is key to avoiding downtime due to overloaded circuits. The Switched Rack PDUs provide an aggregate current draw, which can be viewed remotely or locally, via digital display. In addition, alarms will be generated based on user-defined thresholds to alert users of potential circuit overloads. Users can access, configure, and control the Switched Rack PDUs through Web, SNMP, or Telnet Interfaces.
APC Switched Rack PDU Zero U - power distribution strip
Power distribution strip - rack-mountable
Cord Length
3.05 m
4.3 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Input Connectors
1 x power IEC 60320 C14
Output connectors
16 x power IEC 60320 C13
5.6 cm x 4.4 cm x 124 cm
2 years warranty
P/N: SMX3000RMHV2UNC, SU1400RMXLI3U-3EW, SU1400RMXLIB3U, SU2200RMI3U.1, SU2200RMXLI3U-3EW, SU3000RMXLI3U-3EW, SU5000RMI5U-3EW, SU5000RMXLI5U-3EW, SUA2200RMXLI3U, SUA3000I, SUA3000R2IX322, SUA3000RMI, SUA750IX38, SURT3000XLI/S, SURT3000XLI-BRZ, SURT3000XLI-GLD, SURT3000XLI-SLV, SURT3000XLI-TU
Cord Length
3.05 m
Input Voltage
AC 230 V
Input Voltage Range
AC 200 - 250 V
Frequency Required
47 - 63 Hz
Input Connectors
Output Voltage
AC 230 V
Max Electric Current
10 A
Power cable - integrated - 3.05 m
Rack Mounting Kit
Included
VDE
-5 °C
45 °C
5 - 95%
5.6 cm
4.4 cm
124 cm
4.3 kg
P/N: SMX3000RMHV2UNC, SU1400RMXLI3U, SU1400RMXLI3U U, SU1400RMXLI3U-1EW, SU1400RMXLI3U-2EW, SU1400RMXLI3U-3EW, SU1400RMXLIB3U, SU2200R3IBX120, SU2200RMI3U.1, SU2200RMXLI3U, SU2200RMXLI3U-1EW, SU2200RMXLI3U-2EW, SU2200RMXLI3U-3EW, SU3000R3IBX120, SU3000R3IX160, SU3000RMINET, SU3000RMINET-1EW, SU3000RMINET-2EW, SU3000RMINET-3EW, SU3000RMTX136, SU3000RMXLI3U, SU3000RMXLI3U-1EW, SU3000RMXLI3U-2EW, SU3000RMXLI3U-3EW, SU5000R51BX120, SU5000R5IBX120, SU5000R5TBX135, SU5000RMI5U, SU5000RMI5U-1EW, SU5000RMI5U-2EW, SU5000RMI5U-3EW, SU5000RMXLI5U, SU5000RMXLI5U-1EW, SU5000RMXLI5U-2EW, SU5000RMXLI5U-3EW, SU700RMI2U-1EW, SU700RMI2U-2EW, SU700RMI2U-3EW, SUA1000RMI2U, SUA1000RMI2U-3EW, SUA1000RMI2U-GLD, SUA1500RMI2U, SUA1500RMI2U-2EW, SUA1500RMI2U-SLV, SUA2200RMI2U-1EW, SUA2200RMI2U-SLV, SUA2200RMXLI3U, SUA3000I, SUA3000R2IX322, SUA3000RMI, SUA3000RMI2U, SUA3000RMI2U-1EW, SUA3000RMI2U-2EW, SUA3000RMI2U-3EW, SUA3000RMI2U-BRZ, SUA3000RMI2U-GLD, SUA3000RMI2U-SLV, SUA750IX38, SUA750RMI1U, SUA750RMI2U, SUA750RMI2U-3EW, SUA750RMI2U-BRZ, SUA750RMI2U-GLD, SUA750RMI2U-SLV, SURT3000XLI, SURT3000XLI/S, SURT3000XLI-BRZ, SURT3000XLI-GLD, SURT3000XLI-SLV, SURT3000XLI-TU
Scroll to top
