BT.com
Wishlist
APC AP7921 Switched Rack PDU
£576.78
16 in stock
£576.78
Add to wishlist
Delivery
Standard 1-3 working days
APC's Switched Rack Power Distribution Units (PDUs) are premium solutions to many of the power management problems seen in today's IT environments. Some of the problems are unauthorized use of power outlets, locked-up equipment, in-rush current, overloaded circuits, and the need of remote access to power outlets in the rack. The Switched Rack PDUs address these problems through individual outlet control, power on and off delays, current monitoring, alarm thresholds, and network management. Individual outlet control allows users to turn outlets on, turn outlets off, or recycle power to equipment, which can reboot locked-up equipment and avoid unauthorized use of outlets. Power delays allow users to determine the order in which equipment is powered up or down. Utilizing the power delay feature will avoid in-rush current, which can cause overloads. Monitoring the current draw at the rack level is key to avoiding downtime due to overloaded circuits. The Switched Rack PDUs provide an aggregate current draw, which can be viewed remotely or locally, via digital display. In addition, alarms will be generated based on user-defined thresholds to alert users of potential circuit overloads.
APC Switched Rack PDU - power distribution strip
Power distribution strip - external
Rack Size
19" - 1U
2.3 kg
Input Voltage
AC 208/230 V
Output Voltage
AC 208/230 V
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13
Ethernet 10/100
Remote Management Protocol
SNMP, Telnet, HTTP
Microsoft Windows NT 4.0, Microsoft Windows 98/2000/XP
44.5 cm x 10.8 cm x 4.5 cm
2 years warranty
P/N: AR3100, AR3150, SMX3000RMHV2UNC, SU2200RMI3U.1, SU2200RMXLI3U-3EW, SU2200RMXLINET-3EW, SU3000RMINET-3EW, SU3000RMXLI3U-3EW, SU5000RMI5U-3EW, SU5000RMXLI5U-3EW, SUA2200RMXLI3U, SUA3000I, SUA3000R2IX322, SUA3000RMI, SURT3000XLI/S, SURT3000XLI-BRZ, SURT3000XLI-GLD, SURT3000XLI-SLV, SURT3000XLI-TU
Height (Rack Units)
1U
Rack Size
19"
Input Voltage
AC 208/230 V
Input Connectors
Output Voltage
AC 208/230 V
Max Electric Current
16 A
Remote Management Interface
Ethernet 10/100
SNMP, Telnet, HTTP
1 x LAN - RJ-45 , 1 x serial - RJ-12
Power cable - external - 2.5 m , Serial cable - external
Rack Mounting Kit
Included
LCD display, LED display
FCC Class A certified, UL, VCCI, C-Tick, cUL, ICES-003, IEC 61000-3-2, IEC 61000-3-3, VDE, EN55024, EN55022 Class A
Software Included
Drivers & Utilities
45 °C
Min Storage Temperature
-25 °C
Max Storage Temperature
65 °C
0 - 95%
Humidity Range Storage
0 - 95%
44.5 cm
10.8 cm
4.5 cm
2.3 kg
P/N: AR3100, AR3150, SMX3000RMHV2UNC, SU2200R3IBX120, SU2200RMI3U.1, SU2200RMXLI3U, SU2200RMXLI3U-1EW, SU2200RMXLI3U-2EW, SU2200RMXLI3U-3EW, SU2200RMXLINET-1EW, SU2200RMXLINET-2EW, SU2200RMXLINET-3EW, SU3000R3IBX120, SU3000RMINET, SU3000RMINET-1EW, SU3000RMINET-2EW, SU3000RMINET-3EW, SU3000RMTX136, SU3000RMXLI3U, SU3000RMXLI3U-1EW, SU3000RMXLI3U-2EW, SU3000RMXLI3U-3EW, SU5000R51BX120, SU5000R5IBX120, SU5000R5TBX135, SU5000RMI5U, SU5000RMI5U-1EW, SU5000RMI5U-2EW, SU5000RMI5U-3EW, SU5000RMXLI5U, SU5000RMXLI5U-1EW, SU5000RMXLI5U-2EW, SU5000RMXLI5U-3EW, SUA2200RMI2U-1EW, SUA2200RMI2U-SLV, SUA2200RMXLI3U, SUA3000I, SUA3000R2IX322, SUA3000RMI, SUA3000RMI2U, SUA3000RMI2U-1EW, SUA3000RMI2U-2EW, SUA3000RMI2U-3EW, SUA3000RMI2U-BRZ, SUA3000RMI2U-GLD, SUA3000RMI2U-SLV, SURT3000XLI, SURT3000XLI/S, SURT3000XLI-BRZ, SURT3000XLI-GLD, SURT3000XLI-SLV, SURT3000XLI-TU
Scroll to top
