BT.com
Wishlist
APC 19" Rack LCD Console
£1,009.89
£1,009.89
Add to wishlist
Delivery
Standard Due date unavailable
The Rack LCD Console features a 17" LCD panel, a full keyboard, and a touch pad in a rackmountable sliding housing. The Rack LCD Console is intended for use with compatible target devices (a KVM switch or server). The device is easily installed and minimizes support and maintenance costs, ensuring lower cost of ownership. The ultra-thin LCD screen, touchpad technology, and easy-to-install slide rails combine to form a high-quality, streamlined solution built for server management. The Rack LCD can be used in a variety of IT environments, from computer rooms to large data centers.
APC LCD Console - KVM console - 19"
KVM console - 19"
Keyboard, touchpad
Native Resolution
1280 x 1024
Pixel Pitch
0.26 mm
Input Connectors
VGA
48.2 cm x 66.5 cm x 4.4 cm
Height (Rack Units)
1U
17.4 kg
UL, VCCI, C-Tick, GOST, EN 60950, EN55022, NOM, VDE, IEC 60950, EN55024, CCC, RoHS, KCC, FCC Part 15 A, REACH
2 years warranty
Display Type
KVM console / TFT active matrix
Diagonal Size
19"
Native Resolution
1280 x 1024
Pixel Pitch
0.26 mm
Height (Rack Units)
1U
17.4 kg
Input
Keyboard, touchpad
KVM (SPHD-18) , USB , USB (Type B) , Management (RJ-11)
1 x keyboard / mouse / video cable , 1 x video / USB cable , 1 x USB cable , 1 x data cable
Rack Mounting Kit
Included
Power Supply
Internal
32 Watt
0 - 80% (non-condensing)
Scroll to top
