BT.com
Wishlist
APC 17" Rack LCD Console w/ Integrated 8-Port Analog KVM Switch
APC 17" Rack LCD Console w/...
£1,301.44
Hurry, only 2 left in stock!
£1,301.44
Add to wishlist
Delivery
Standard 1-3 working days
The Rack LCD Console features a 17" LCD panel, a full keyboard, and a touch pad in a rackmountable sliding housing. The Rack LCD Console is intended for use with compatible target devices (a KVM switch or server). The device is easily installed and minimizes support and maintenance costs, ensuring lower cost of ownership. The ultra-thin LCD screen, touchpad technology, and easy-to-install slide rails combine to form a high-quality, streamlined solution built for server management. The Rack LCD can be used in a variety of IT environments, from computer rooms to large data centers.
APC LCD Console - KVM console - 17"
KVM console - 17"
KVM Switch
PS/2 - 8 ports
Touchpad, 8 port KVM switch
Input Connectors
VGA
48.3 cm x 71.1 cm x 4.3 cm
Height (Rack Units)
1U
14 kg
UL, C-Tick, GOST, cUL, EN 60950, VDE, IEC 60950, CCC, IC, RoHS, FCC Part 15 A, REACH
2 years warranty
Display Type
KVM console / TFT active matrix
Diagonal Size
17"
Built-in Devices
8 port KVM switch
Height (Rack Units)
1U
14 kg
Input
Touchpad
KVM
KVM switch - 8 ports
Keyboard / Mouse Interface
PS/2
8 x KVM , USB
Cable organizer
1 x keyboard / mouse / video cable
Rack Mounting Kit
Included
Power Supply
Internal
Scroll to top
