BT.com
Wishlist
AOC Value I2769VM 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Delivery
Standard Due date unavailable
This Full HD monitor blows the contents of your Android devices up to an impressive size: With the innovative MHL interface (Mobile High-Definition Link) high-resolution photos, videos and games can be displayed directly from a smartphone or tablet PC on the huge 68.6 cm (27?) screen. A practical side effect: the mobile gadgets get charged at the same time. The LED model utilizes the high-quality IPS display technology, which, besides providing strong contrast and brightness, stands for exceptionally good color fidelity and viewing angle stability. This monitor will be a big stage for your photos and videos!
What's in the box
  • AOC Value I2769VM
  • VGA cable
  • HDMI cable
  • Audio cable
  • Software
AOC Value I2769VM - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
62.2 cm x 13 cm x 44.9 cm
4.99 kg
Environmental Standards
ENERGY STAR Qualified
GOST, FCC, RoHS, ISO 9241-307, TUV Bauart, TCO '05, EuP, NRTL
3 years warranty
Display Type
Energy Class
Class A
35 kWh
24 W
Diagonal Size
27"
Viewable Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
55 - 77 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Eco-Mode, i-Menu, e-Saver technology, Mobile High-Definition Link (MHL), Screen+
4.99 kg
2 x HDMI , VGA , Headphones
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable , 1 x HDMI cable , 1 x audio cable
AC 90 - 240 V (50/60 Hz)
43 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Included Software
Drivers & Utilities
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
Accessories
£9.99
£7.75
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£26.02
£49.75
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£62.13
Scroll to top
