BT.com
Wishlist
AOC Value I2276VWM 21.5" 1920x1080 5ms VGA HDMI IPS LED Monitor
Clearance
While Stocks Last
Delivery
Standard Due date unavailable
The AOC I2276VWM display offers high performance and extra convenience for the most discerning users. This 21.5-inch ADS-IPS monitor delivers sharp contrast ratios, stunning imagery and accurate colors with viewing angles of up to 178 degrees. With Full HD 1920 x 1080 resolution you'll enjoy photos, movies, games and more in gorgeous detail. The fast 5 ms response time makes it ideal for the most demanding applications. Easily connect your computer, media player and game console with the VGA and HDMI ports. The adjustable stand and built-in VESA mount give you the option to use it at your desk or mount it on the wall. From systems integration to family entertainment, this monitor will impress at any office or home.
AOC Value I2276VWM - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
27 kWh
Power Consumption (On mode)
18 W
Panel Type
ADS-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, MHL
Display Position Adjustments
Tilt
55.14 cm x 22.1 cm x 40.04 cm
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, GOST, FCC, RoHS, ISO 9241-307, TCO '06, cTUVus, TUV Bauart, EuP, EAC, Ukrain Safety
3 years warranty
Display Type
Energy Class
Class A
27 kWh
18 W
Diagonal Size
21.5"
Viewable Size
21.5"
Panel Type
ADS-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+, i-Care
55.14 cm x 22.1 cm x 40.04 cm - with stand
VGA , MHL / HDMI (HDCP) , Headphones
Mechanical
Tilt
Tilt Angle
-4/+21.5
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x HDMI cable
Power Supply
Internal
25 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Included Software
Drivers & Utilities
ENERGY STAR Certified
Limited warranty - 3 years
Accessories
Accessories
£138.85
StarTech.com Articulating Monitor Arm
Quicklinx: BHCN | In Stock
£122.23
StarTech.com Dual Monitor Stand
Quicklinx: C19Z | In Stock
£83.23
StarTech.com Cubicle Monitor Hanger
Quicklinx: CFQK | In Stock
£57.19
StarTech.com TV/Monitor Arm - Wallmount
Quicklinx: CFR4 | In Stock
£78.40
Other bundles
£9.99
£6.87
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.73
£35.97
£48.72
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.27
Scroll to top
