BT.com
Wishlist
AOC U3477PQU 34" 3440 x1440 5ms DVI-D HDMI IPS Monitor
Delivery
Standard Due date unavailable
Expand your possibilities with the spacious 34-inch WQHD monitor. This 21:9 display offers UltraWide 3440 x 1440 resolution for gorgeous detail and more room to get things done. Built-in 7-watt speakers and 1.07 billion colors complete the cinematic experience. The extra space lets you split your screen into multiple panes for increased efficiency. Use picture-by-picture mode to display a spreadsheet and financial software or picture-in-picture to watch a movie while you chat with a friend. Connect devices, peripherals and even a second computer with HDMI, DisplayPort, and USB 3.0. With so much space, you'll always see the big picture.
AOC Pro-line U3477PQU - LED monitor - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class C
Energy Consumption per Year
92 kWh
Power Consumption (On mode)
63 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
3440 x 1440 at 60 Hz
Pixel Pitch
0.2325 mm
Brightness
320 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
82.8 cm x 22.92 cm x 62.45 cm
10 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, GOST, RoHS, TCO '06, ISO9241-307
3 years warranty
Display Type
Energy Class
Class C
92 kWh
63 W
Diagonal Size
34"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.2325 mm
Brightness
320 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
HDCP, Eco-Mode, i-Menu, e-Saver technology, Mobile High-Definition Link (MHL)
82.8 cm x 22.92 cm x 62.45 cm - with stand
10 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
3 Watt
DVI-D , VGA , MHL / HDMI , DisplayPort , USB 3.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , 2 x USB 3.0 downstream (Type A)
Mechanical
Tilt Angle
-5/+24
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Built-in speaker, VESA interface support
1 x power cable , 1 x VGA cable , 1 x DisplayPort cable , 1 x HDMI cable , 1 x USB cable , 1 x audio cable
70 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.1 Watt
On / Off Switch
Included Software
Drivers & Utilities
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
Accessories
£9.99
£6.94
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.78
£36.49
£49.42
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£56.07
Scroll to top
