BT.com
Wishlist
AOC Pro-line M2060PWQ 19.5" 1920 x 1080 5ms VGA, DisplayPort LED Monitor
AOC Pro-line M2060PWQ 19.5" 1920 x...
£108.98
£108.98
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The AOC Pro-Line M2060PWQ offers energy-saving LED backlight, Full HD resolution and high contrast ratios which delivers clear, vibrant images at your home or office. Features like height adjustable stand and Eco mode & E-saver improve ergonomics and further reduce power consumption.
AOC Pro-line M2060PWQ - LED monitor - Full HD (1080p) - 19.53"
LED-backlit LCD monitor - 19.53"
Panel Type
MVA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.22 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
VGA, DisplayPort
Display Position Adjustments
47.76 cm x 17.95 cm x 35.83 cm
Environmental Standards
ENERGY STAR Qualified
Plug and Play, RoHS, TUV Bauart, TCO Displays 6.0
3 years warranty
Display Type
Diagonal Size
19.53"
Panel Type
MVA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.22 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, i-Menu, e-Saver technology
47.76 cm x 17.95 cm x 35.83 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DisplayPort
Mechanical
Tilt Angle
-5/+22
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x DisplayPort cable , 1 x audio cable
23 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
ENERGY STAR Certified
Limited warranty - 3 years
Accessories
C2G 2M HD15 M/M UXGA MONITOR CBL W/ FE
Quicklinx: 63P0 | In Stock
£8.88
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£44.23
£17.40
£9.80
£22.39
£12.42
£15.15
Scroll to top
